- 8 Jul 2010
- Staffordshire
I'll be purchasing the parts soon but I'm still kind of new to the world of home servers. So I was hoping you guys and girls would give the following spec the once over and answer a few questions. I've split the spec into two parts as I'll be buying the second group of parts a month or two (at the most) after the first group. This is partly due to being busy at the mo' and partly to give me time to do some spring cleaning of my data. Oh, and things marked with an * have already been purchased
*Case - Fractal Design Define XL R2
CPU - Intel Xeon E3 1220-V3
Mobo - Supermicro X10SL7-F
RAM - 2x8GB... haven't decided on the exact make or model yet.
*SSD - 120GB OCZ Vertex 2E
*HDD's - 2x2TB WD Red's, 1x2TB WD Green and 1x3TB WD Red and Green... only the Reds will be used in RAID
PSU - I'll either reuse my trusty Corsair AX650 or more likely get a SeaSonic 660XP2
At a later date, I will buy...
HDD's - at least 3x3TB WD Red's for RAID 6.
Accessories - and additional HDD cage and possibly better fans for the XL R2
Other - A UPS if I have the money.
- So, how does the spec look?
- Is it a good idea to space out the purchases of the additional HDD's to get stock from different batches?
- I know that RAID isn't intend as a backup solution. What's the best way to backup my data locally? It'll be backed up online but that's just the belt, I want (localised) braces to... I draw the line at suspenders though.
- I'm pretty sure I know the answer but it was difficult to verify so... Do I need to worry about the number of ranks the RAM has? Is it preferable to have more or less ranks? I know this can be an issue for much higher end servers.
- I'm currently leaning toward ZFS, why should I change my mind?
