- 1 Apr 2013
- Dundee, Scotland
It is really quite subjective. But from my experience '4K' is a developing technology in its early stages. It's something that will get better with time, when the software and graphics hardware catches up properly. When that does happen there will be a broader choice of '4K' monitors available and they will likely perform better in some areas than the Acer.
The ROG Swift on the other hand is something that the software is completely ready for. And although running the 2560 x 1440 resolution at high frame rates is very demanding I still feel some higher end GPUs can make a good go of it - depends on the settings you want to use and games you play really. There is still good headroom in that monitor if you don't have a super-powerful multi-GPU setup as well.
I play normally FPS bf4 and such, a few MMO's starcraft2 and WOD,
If I went 4k id buy
YOUR BASKET
1 x Acer 4k2k XB280HK 28" G-Sync Gaming Widescreen LED Monitor - Black/Red £499.99
2 x EVGA GeForce GTX 780 SC ACX Superclock 6144MB GDDR5 PCI-Express Graphics Card (06G-P4-3787-KR) £467.99 (£935.98)
Total : £1,450.07 (includes shipping : £11.75).
If I went with the swift
YOUR BASKET
1 x Asus ROG Swift PG278Q 27" G-Sync 144Hz Gaming Widescreen LED Slim Bezel Monitor - Black/Red £695.99
Total : £705.59 (includes shipping : £8.00).
Id just use my 780 just now to see what the new Nvidia bring to the market, if th 800 series is crap then id probably just buy another 780 and add them both to my WC loop?
