From your speedtest, it looks like you're on standard DSL which has a poor upload. If you switched to BT/Sky fiber then that should dramatically increase your upload speed (Between 10Mbps and 20Mbps).
Dvd-r would be the cheapest option. Maybe you have an old laptop hard drive and USB enclosure handy?
USB or an SD card will cost an order of magnitude more than optical media but if the USB/SD were to be returned then it'd be different.
Would not fancy uploading that much at work unless it could be done without anyone knowing and you'd still need to get the data to work.
You can probably massively reduce that file size using 7zip with bzip2 on Ultra.
I compressed the world data and configuration for my old mineshaft server from around 20gb down to 10gb or so
They are RAW files but they are to send to my friend, clients are given JPEGS on a CD or dropbox due to their smaller size.
I'm going past work soon, will check the speed and if it's slow will pinch a couple of flash drives and stick them in the post.
P.S - This has made me look at new internet providers now. Seem daft to have one so slow when we are happy to pay for such trivial household things every day. Never really needed decent internet speeds before!
Are you as slow as OPs upload speed?![]()
Drop box?
