Hi guys
I've been building my own PC's for 10-15 years but have never got into the Water Cooling side of things. I am now looking to take the plunge and am hoping you guys can provide me with some advice/opinions
I've spent the last few weeks reading/watching lost of reviews on the latest water cooling gear and cases, beginners and advanced guides etc. and have come up with something I believe will suit my needs.
My current hardware set-up is in my sig., but here is my current cooling setup:
CPU: Antec Kuhler h2o620 - using 120mm fan/radiator that came with pack, pulling air through the rad out of the back of the case
Case Top: 200m exhaust fan that came with case (blue LED)
Case Front: 2 x Corsair SP120 Quiet Edition intakes
I will be looking to keep the current hardware, but swap out the case and of course, the cooling. NB. I will be only looking to do a CPU loop for the moment, possibly adding in a GPU to that loop in the future.
My colour scheme will be 'white, blue, black'. This should work nicely as most of the above hardware above has black and blue in it.
Having looked at quite a few cases, I have decided to go for the 'Phantek Enthoo Luxe' in white. It seems a very good case, has all the bells and whistles I would want and I think it'll provide me with a nice, clean installation.
For the WC setup, I am thinking of the 'XSPC RayStorm 750 EX360 WaterCooling Kit'. It looks like the 360 rad will fit nicely into the top area of the Luxe case (either pushing or pulling air through it and out of the roof), even with the bay reservoir installed(?) I could drop to the EX240 but I think a 360 will give me a bit more cooling potential (now and in the future) - would you agree? This also has fans included but of course, I could swap these out if I'm not happy with them (or set-up push/pull...if that will fit ofc).
Now, even though the above kit has 'barbs', I would like to pick up some compression fittings. So, I've been looking at the 'Monsoon Free Center Compression Fittings pack (6 fittings) in White'. This is basically as I would prefer compression and well... they are white
For Tubing, I think I'll go for 'XSPC HighFlex Hose in Blue/UV Blue'.
Coolant.... distilled water with some sort of algae prevention (any thoughts here would be appreciated).
With this all in place, I can have my colour scheme that I want and my current hardware.
For draining, I was thinking of adding some sort of contraption to the 'back' connection on the bay reservoir (the one on the bottom right). Maybe a short tube/hose with a cap. Or maybe I should go with the 'disconnect the CPU block and hang it in a bucket etc.' method?
So, what do you guys think? Would this work ok? Should I look for different fans for the rad? I'm a little unclear on sizes also for the compression fittings and tube (I've tried to follow what the 'kit' has, but I'm still a little unsure).
I would appreciate your thoughts on anything here
Thanks!
TechniQ
PS - I'm brand new to the forums so hope I have not missed any 'rules' - tell me if I have
Thanks!
TechniQ
