Hi all,
My son's PC is getting a bit long in the tooth and he's finding it struggles with frame-rate issue in GuildWars 2 and other games so we're looking at upgrades. He also wants to get it ready for Dragon Age Inquisition (albeit not max settings!).
The current spec is...
Gigabyte 965P-DS3 (Rev 3.3) Motherboard (click for specs)
Intel Core 2 Duo E6600 CPU @ 2.40Ghz
4gb RAM (I'm not sure of type but according to the motherboard specs it will be DDR2 800 at best)
AMD HD 5700 Graphics Card (1gb RAM)
What would be the best, most cost effective way of significantly improving performance and achieving a few more years of reasonable gaming on it? On a budget of say £400 - £500?
I'm guessing the CPU is holding performance back the most? And that to upgrade that means upgrading the motherboard, CPU and RAM all at the same time (due to what the motherboard will support)?
Is the graphics card passable for now do you think?
Thanks in advance for any pointers!
Tem
Tem
