** FREE 8GB 2400MHz MEMORY KIT & AMD GOLD VOUCHER WITH POWERCOLOR 290/290X PCS+ CARDS!! **
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
A truly insane offer, when you buy a Powercolor 290/290X PCS+ you will get for FREE:-
AMD Gamer 8GB (2x4GB) PC3-19200C11 2400MHz Dual Channel Memory Kit (R938G2401U1K) @ £89.99 inc VAT
AMD Memory is designed to deliver memory that is optimized and certified for AMD Platforms and components and also delivers quality and reliability to compatible chipsets and processors from other manufacturers. High-quality DRAM parts (no ETT) help ensure no dropouts and no data loss. With AMD memory you get the performance you need for all your applications.
Features:
- Black PCB
- Black high performance heatspreaders
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- CAS Timings: 11-12-12-31
- Dual Channel Kit: (2x4GB)
- 100% tested at 2400MHz in AMD 990FX & Kaveri APU based motherboards
- Lifetime Warranty
Only £89.99 inc VAT.
ORDER NOW
AMD Radeon GOLD Reward Ticket (Emailed) @ £89.99 inc VAT
Choose 3 FREE Games from AMD between now and end of this year with this GOLD Reward for purchasing an R9 295/290/280 series graphics card.
1. www.AMD.com/radeonrewards
2. Sign in or create an account
3. Follow the instructions to redeem your offer with the code on the ticket
4. This voucher will automatically attached to your order when ordering a qualifying car
5. Ensure you put a valid email address when placing your order as your Golden Ticket will be emailed her or you can retrieve by logging into your account at OcUK.
ORDER NOW
The qualifying cards are:-
Powercolor Radeon R9 290X PCS+ OC 4096MB GDDR5 PCI-Express Graphics Card with FREE AMD 8GB 2400MHz Memory Kit @ £389.99 inc VAT
PCS+ Version features Powercolor's amazing tri-fan cooler, for much lower noise levels whilst offering superior cooling. Along with a great overclock out the box, this card runs at 1050MHz core and 5400MHz memory.
AMD Radeon R9 290X is a new graphics card powered by the latest AMD Radeon™ R9 290X graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:-
- Radeon R9 290X
- GPU: Hawaii XT
- Litecoin Hash Rate: 850-1000
- Stream Processors: 2816
- ROPS: 64
- Core Speed: 1050MHz
- Memory Speed: 5400Mhz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- Cooling: 2-Slot Blower Fan
- Fan Speed: 20% - 40% (Quiet Mode) & 20%-55% (Uber Mode)
- PCI-Express X16 lane required
- 750W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Comes with BF4 Voucher included in the box
- Warranty: 2yr
Only £389.99 inc VAT.
ORDER NOW
Powercolor Radeon R9 290 PCS+ OC 4096MB GDDR5 PCI-Express Graphics Card with FREE AMD 8GB 2400MHz Memory Kit @ £305.99 inc VAT
PCS+ Version features Powercolor's amazing tri-fan cooler, for much lower noise levels whilst offering superior cooling. Along with a great overclock out the box, this card runs at 1040MHz core and 5400MHz memory.
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:
- Radeon R9 290
- GPU: Hawaii Pro
- Litecoin Hash Rate: 800-950
- Stream Processors: 2560
- Core Speed: 1040MHz
- Warranty: 2yr
Only £305.99 inc VAT.
ORDER NOW
Also in case anyone was wondering the AMD memory works fine in Intel chipset mainboards at 2400MHz as well. :)
The value of these items means your getting a 290X for less than £300 and a 290 for less than £200.
This bundle promotion is EXCLUSIVE TO OVERCLOCKERS UK!! :D
Are these 290s the new revision? Kinda tempted to try tri-fire but would need a block for it.
That's a great price BTW and insane extras... n1 Gibbo :)
Yes they only arrived today direct from Powercolor. :)
Its a great deal as memory prices are exploding, I can't even buy an 8GB 1333MHz for 1000pc much below £60 at trade levels now, so to get a FREE 2400MHz and the AMD Gold voucher, very good bargain!
Thats amazing! Pity ive already got crossfired cards... :D Maybe i should go for a better motherboard and tri-fire ;)
Very good deal but it's a shame the prices for the graphics cards have gone up.
Given a choice I would rather buy the cards cheaper without any of the free items as I don't need 8GB of AMD gamer memory.
Perfectly timed post, was about to hit buy on an MSI Radeon R9 290X Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card @ £399.95
Cheers!
Edit: Just noticed it requires a 750w psu, is that a hard and fast rule? I've got a Corsair TX 650W ATX SLi Compliant Power Supply (CMPSU-650TXUK).
Cheers!
Corsair unit should be fine.
290X price has not changed much.
290 was £269.99 on previously weekly offer, that's £35 cheaper than price now and you can't buy even a 4GB ram kit now for £35 let alone a 8GB 2400MHz kit, this deal is far better value for money. :)
