New pc help :3
Corsair RM Series 850W is plenty good enough! for £30 more you can get Samsung 840 Evo Series 250GB SSD:)
That's a solid build.
Don't go for the Corsair RM. I would suggest either the EVGA Supernova G2 or the Superflower Leadex.
You can choose any psu with a quick phonecall to ocuk.
What graphics card/s are you looking to run ?
One other thing to note. You can ask ocuk to build you a custom spec pc. This way you have a wider choice of components, as not all are listed in the configurator.
You just post a 'basket' in the pre sales section, and ask them for a quote :)
Just the 780 ti for the moment :3
You would need a 550W for a single GTX 780. If you want to sli in the future then go for a 750W/850W.
What is your budget for the pc ? Is this just a gaming pc ?
Also do you need peripherals such mouse/keyboard/speakers? And do you need a monitor and a copy of windows ?
