** GRID AUTOSPORT, SHADOW RUN RETURNS & MORE FREE WITH QUALIFYING INTEL PROCESSORS!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
These are FREE with the following qualifying products:-
screenshot2.jpg~original
EPIC POWER BUNDLE: Intel 4790K, Gigabyte Z97X-Gaming 7, Kingston 16GB 2400MHz Kit, Superflower 1000W Platinum PSU & FREE STUFF!! **£50 SAVING** @ £611.93 inc VAT
With this EPIC Bundle you don't only SAVE £50.00, you also get lots of FREE stuff too!!
Taking some of the very best performance components which also represent great value for money, here you have the base for a very high performance machine or great upgrade to your current PC Gaming system.
Due to the components used for the system its also an excellent base for overclocking, all you need to consider is a better cooling solution from say the likes of Phanteks, Prolimatech or Corsair or even a custom water-cooling setup.
Free Items:-
- Arctic Silver 5 thermal compound, can reduce temperatures by upto 11c
- OcUK Mug
- OcUK Gaming mouse mat
Components in this Bundle
- CPU: <a href="http://www.overclockers.co.uk/showproduct.php?prodid=CP-539-IN" target="_blank">Intel Core i7-4790K 4.00GHz (Devil's Canyon) Socket LGA1150 Processor - Retail</a><br>
- Motherboard: <a href="http://www.overclockers.co.uk/showproduct.php?prodid=MB-491-GI" target="_blank">Gigabyte Z97X-Gaming 7 Intel Z97 (Socket 1150) DDR3 ATX Motherboard</a><br>
- Memory: <a href="http://www.overclockers.co.uk/showproduct.php?prodid=MY-182-KS" target="_blank">Kingston HyperX 16GB (2x8GB) PC3-19200C11 2400MHz Dual Channel Kit - Black/Red (HX24C11BRK2/16-OC)</a><br>
- Power Supply: <a href="http://www.overclockers.co.uk/showproduct.php?prodid=CA-006-SF" target="_blank">SuperFlower Leadex Platinum 1000W Fully Modular "80 Plus Platinum" Power Supply - Black</a><br>
Only £611.93 inc VAT.
ORDER NOW
EPIC BUNDLE: Intel 4790K, Gigabyte Z97X-Gaming 7, Kingston 16GB 2400MHz Kit, Superflower 750W PSU & FREE STUFF!! **£50 SAVING** @ £545.93 inc VAT
Free Items:-
- OcUK Mug
- Power Supply: <a href="http://www.overclockers.co.uk/showproduct.php?prodid=CA-011-SF" target="_blank">SuperFlower Golden Green HX 750W "80 Plus Gold" Power Supply - Black</a><br>
Only £545.93 inc VAT.
ORDER NOW
Intel Core i7-4790K 4.00GHz (Devil's Canyon) Socket LGA1150 Processor - Retail @ £259.99 inc VAT
Want to tune every aspect of your system for the ultimate in total system control. Then the new unlocked Intel Core processors which enable system tuning for the processor cores, memory, graphics, and power, were made for you. Whether you are a novice overclocker or a seasoned veteran, these processors will have you singing their praises in no time.
Looking for the perfect processor to build your gaming rig around? But you also want to edit your action videos and photos? But to do this you know you need serious performance. Not to worry - Intel is happy to announce our first 4GHz base frequency quad core processor. If it is performance you crave, then this is the processor you have been waiting for. But what if you feel the need to overclock your system to squeeze every last bit of performance out of it? Well, then this is still the perfect processor you. The lastest 4th gen Intel Core i5 and Intel Core i7 processors, paired with the latest Intel 9 Series H and Z chipsets, will get you the results you want. Add in features like built in visuals and Intel Quick Sync Video, which allows the conversion of media from one device to another and prepares your media from one device to another and prepares your media to share online at incredible speeds, and these are processors that meet every need you have.
The Intel Core processor family delivers a great PC experience. Whether you are looking for improved performance, greater adaptability, or differentiated visual features, Intel has the processor to fit your needs. Whether you use your PC for creativity, playing games, or everyday task such as homeworkd and email, these new processors make it easier to design, render, edit, play, and share.
Intel Core and for Intel Core i7 processors, Intel Hype-Threading Technology allows each processor core to work on two task at the same time, improving multitasking, speeding up the workflow, and accomplishing more in less time.
With 4th gen Intel Core processors, you can boot your PC, load applications, and resume from sleep nearly instantaneously thanks to Intel's responsiveness technologies such as Intel Smart Response Technology and Intel Rapid Start Technology.
The 4th gen Intel Core processor family offers hardware-level security that helps protect your devices, your data, and your online transactions.
The 4th gen Intel Core processor family automatically connects to wireless hotspots. Your email, social media, and apps are always updated thanks to Intel Smart Connect Technology. Finally, wirelessly stream your HD / 3D video and games to your TV or projector for presentations and entertainment using Intel Wireless Display Technology.
Features:-
- Improved thermal interface material (TIM)
- Updated packaging materials
- Supported by new Intel 9 series chipset
- Re-engineered for Enhanced Performance & Overclocking
Specification:-
- Lithography Process: 22 nm
- Cores: 4
- Threads: 8
- Frequency: 4.00 GHz (Turbo Mode 4.40GHz)
- Integrated HD 4600 Graphics
- Cache: 8 MB shared L3
- Memory Controller: Dual channel DDR3 1600/1866/2133/2400/2666+ MHz
- Socket: LGA1150
- Memory compatibility: All DDR3 1333MHz and above is compatible
- PSU compatibility: Check out our range of Haswell compatible PSU's - http://www.overclockers.co.uk/productlist.php?groupid=701&catid=123&subid=2597
- 3yr Warranty
Only £259.99 inc VAT.
ORDER NOW
Intel Core i5-4690K 3.50GHz (Devil's Canyon) Socket LGA1150 Processor - Retail @ £189.95 inc VAT
Features:-
Specification:-
- Cores: 4
- Threads: 4
- Frequency: 3.50 GHz (Turbo Mode 3.90GHz)
- Cache: 6MB shared L3
- Socket: LGA1150
- 3yr Warranty
Only £189.95 inc VAT.
ORDER NOW
Intel 4820K 3.70GHz (Ivybridge-E) Socket LGA2011 Processor - Retail (BX80633I74820K) @ £239.99 inc VAT
The new Ivybridge-E processors offer truly un-beatable performance and un-parelled overclocking ability with 4.40Ghz and beyond being truly possible when combined with flagship motherboards, top motherboards, the best memory and water cooling. So if your seeking the best performance or building your dream gaming/benchmarking PC then look no further than Ivybridge-E as it is truly unbeatable.
- Fully Unlocked!
- 4 Cores
- 8 Threads
- 3.70GHz (3.90GHz Turbo)
- 10MB Cache
- Max TDP: 130W
- No onboard graphics
- Intel Hyperthreading
- Intel Virtualization Technology VT-x
- Intel 64
- Intel Enhanced SpeedStep Technology
- Intel Execute Disable Bit
- No Heatsink supplied
- 3yr Warranty
Only £239.99 inc VAT.
ORDER NOW
Intel 4930K 3.40GHz (Ivybridge-E) Socket LGA2011 Processor - Retail (BX80633I74930K) @ £429.95 inc VAT
- Fully Unlocked!
- 6 Cores
- 12 Threads
- 3.40GHz (3.90GHz Turbo)
- 12MB Cache
- Max TDP: 130W
- Intel 64
- 3yr Warranty
Only £429.95 inc VAT.
ORDER NOW
Intel 4960X 3.60GHz Extreme (Ivybridge-E) Socket LGA2011 Processor - Retail (BX80633I74960x) @ £749.99 inc VAT
The new Ivybridge-E processors offer truly un-beatable performance and un-parelled overclocking ability with 4.80Ghz and beyond being truly possible when combined with flagship motherboards, top motherboards, the best memory and water cooling. So if your seeking the best performance or building your dream gaming/benchmarking PC then look no further than Ivybridge-E as it is truly unbeatable.
- Fully Unlocked!
- 6 Cores
- 12 Threads
- 3.60GHz (4.00GHz Turbo)
- 15MB Cache
- Max TDP: 130W
- Intel 64
- 3yr Warranty
Only £749.99 inc VAT.
ORDER NOW
I'd rather have the same price others are offering on the 4790k.
Am toying with idea of trying another in hopes of finding better clocker.
Though should really just wait on Broadwell.
If you paid £269.99 for this chip as an early adopter like myself you would be pretty annoyed not to qualify for the free games. Not a good long term business strategy.
But nobody put a gun to your head and said you had to adopt early, you chose to do so and paid the financial price for it, the bundles and free games suggests these are not "selling like hot cakes" to the intended market and so some sweeteners are required. ;)
