I've had my rig since 2012 now and it's been working fine up until now. When booting it one day it wouldn't recognise my SSD (but I've had that problem before) and I usually fix that by doing a few cold boot cycles.
However when turning my PSU on and off again I noticed a burning smell and when pressing the power button. The CPU fan and case fans spin up for about 3 seconds and then turn off, turn back on again and the cycle repeats but there is no BIOS or any display on the screen.
I've tried:
- New power supply
- New motherboard
- Reseating all the RAM, and in different slot combinations
- Taking the GPU out and just using the on-board GPU - Resetting the CMOS battery
- Taking my after-market cooler off and just using the stock cooler (while replacing the thermal paste)
- External build (just the CPU, CPU fan, PSU, 1 RAM stick, 8-pin CPU power cable, 24-pin motherboard cable) plugged together (both with the old and new PSU and motherboard)
- Checking the capacitors and stand-offs (nothing wrong)
The only progress I've seen is when I reset the CMOS battery the fans spin for about 5 seconds longer but then stop, then start to spin up again. The LEDs on the motherboard all work fine. I don't know what else to try apart from buying a new CPU and RAM stick.
I don't have a motherboard speaker to plug in (I've never heard it beep even when it was working fine)
Any help would be appreciated.
I've tried:
- New power supply
- New motherboard
