Can someone recommend the best fans for a 360mm rad high presure needed.
26 Jan 2004
Scotland
price is not a issue need the best fans you can get with the highest pressure output
also need a 360mm rad gasket that is compatible with my promochill 360mm rad
as currently the fans i have i dont think there pulling the air through the rad fast enough to cool it causing my R9 295x2 to heat up but at a slow rate... i need to stop that happening.
well i wanted them out today and no one was replying so i purchased these ones.
hope i made the right call as i really need high static presure to pull the air through my 360 rad.
Noctua NF-F12 IndustrialPPC 3000RPM PWM 120mm High Performance Fan £17.49 3 £52.47
XSPC 360mm Radiator Gasket
they should be awesome fans just really noisy. ive only just seen this thread so was about to suggest sp120 pwm performance editions. they perform similar to the normal poo brown and white noctuas but are cheaper and look nicer.
needed high rpm high static pressure, i think i made the right choice.
they should perform awesomely and they will be getting hooked up to a fan controller. :)
yeah you have ive not seen any fans with better figures than those new noctuas. i always use a fan controller now so when im browsing etc turn the fans right down then turn them up for gaming. noise isnt an issue with my 2nd pc its in my bedroom with air con and my dialysis machine haha.
But they run at such a high rpm at 12v even when you do turn the volts down it will be at a relatively high rpm
Those fans are beasts, probably one of the strongest ones out there. I use akasa vipers and black apaches personally because I want a more quiet approach :P
Ah that is interesting I didn't think you needed gaskets any more, as a matter of fact to new radiators come with them now ?
I know my old wc setup came with one. I had totally forgot about them.
do they actually make much difference in performance ?
they create more static pressure as air will not be leaking out the sides of the fans... though some rads dont need them depending on what fans you use..
