Audio-Technica gaming headsets are now available!
OcUK Staff
12 Apr 2008
OcUK HQ
The Audio-Technica ATH-AG1 and the ATH-ADG1 are the very latest headsets to be introduced to our gaming range. Audio-Technica have over 50 years of engineering technology experience within the professional audio industry; constructing award winning and state of the art audio equipment.
Both models are designed for gaming, the ATH-AG1 created with a closed structure and the ATH-ADG1 created with an open structure and producing unrivalled audio quality. Characterised by the 3D wing system a patent for wearing in comfort for long periods of use.
Find out more here: http://www.overclockers.co.uk/LP/audio-technica.php?campaign=social/forum/2014/08/audiotechnica
Audio Technica ATH-ADG1 Gaming Headset @ £264.95 inc VAT
The first headset of its kind to harness over 40 years of audio engineering technology, the ATH-ADG1 provides players with the ultimate gaming experience. With its lightweight, honeycomb aluminum casing, the open-air headphones offer a completely natural sound experience. Premium 53 mm drivers with Bobbin-wound CCAW voice coils – the first of its kind in a gaming headset – provide unrivaled sound quality and clarity as part of the comfortable, open-air design.
The ATH-ADG1 also allows for in-game voice communication through its state-of-the-art microphone feature, and comes equipped with a 1.0 m fixed cord and 2.0 m extension to fit any environment. A detachable USB DAC with built-in headphone amplifier and 3.5 mm connector is also included.
Features:
- Premium 53 mm drivers with Bobbin-wound CCAW voice coils, the first of its kind in a gaming headset
Audio-Technica’s core Open-Air design, engineered to provide unrivaled sound quality, clarity and comfort
- State-of-the-art microphone, with 100° range of motion and muting capability, provides crystal clear in-game voice communication
- Detachable USB DAC with built-in headphone amplifier and 3.5 mm connector
- Self-adjusting 3D wing-support system offers improved comfort designed for extended wear
- 1.0 m fixed cord with a 2.0 m extension to fit any environment
Specification:
- Type: Open-air Dynamic
- Driver Diameter: 53 mm
- Frequency Response: 5 – 30,000 Hz
- Maximum Input Power: 700 mW
- Sensitivity: 100 dB/mW
- Impedance: 38 ohms
- Weight (without cord): 280 g
- Cord: 1.0 m
- Connector: 3.5 mm (1/8”) mini stereo, gold-plated (4 pole)
- Accessories: USB adaptor, 2.0 m extension cord
- Microphone Type: Condenser
- Microphone Polar Pattern: Unidirectional
- Microphone Frequency Response: 100 – 12,000 Hz
- Microphone Sensitivity: -46.5 dB (0dB=1V/Pa,1kHz)
Only £264.95 inc VAT.
ORDER NOW
Audio Technica ATH-AG1 Gaming Headset @ £239.99 inc VAT
The first headset of its kind to harness over 50 years of audio engineering technology, the ATH-AG1 provides players with the ultimate gaming experience. Premium 53 mm drivers work synchronously with Audio-Technica’s core double air damping system (D.A.D.S.) and optional USB amplifier to deliver deep, resonating bass and total isolation – effectively blurring the line between reality and the virtual world you’ve entered – while a refined, 3D wing-support system provides the comfort to stay as long as you’d like.
The ATH-AG1 also allows for in-game voice communication through its state-of-the-art microphone feature, and comes equipped with a 1.0 m fixed cord and 2.0 m extension to fit any environment. Detachable USB DAC adaptor with built-in headphone amplifier and 3.5 mm gold-plated connector included.
Features:
- Premium 53 mm drivers with Bobbin-wound voice coils specially designed for the ATH-AG1 gaming headset
- Audio-Technica’s core D.A.D.S. structure* with double air damping system delivers deep resonating bass and total isolation
- The dual-layer housing structure utilizes the damping effect of air to improve the linearity of the bass.
Specification:
- Type: Closed-back Dynamic
- Frequency Response: 5 – 35,000 Hz
- Maximum Input Power: 1,000 mW
- Weight (without cord): 310 g
- Cord: 1.0 m
Only £239.99 inc VAT.
ORDER NOW
These quite literally look like mid-fi headphones with a mic tacked onto the side :D
Are they any different to the headphones they appear to be, apart from the fact they have a mic tacked on?
If the answer is "no", that can only be good. :)
If the AG1 isn't a pair of A700s or A900s with a mic tacked on I would eat my hat.
They look like ATH-AD700X's, but if they are then they seem a little overpriced. I doubt they are based on the 900X's, but if they are then the headset is a bargain.
They are ATH-AD700X's but with a mic, Detachable USB DAC, A different paint job and the word gaming thrown in hence the mahoosive price hike over the standard ATH-AD700X's.
I wouldn't underestimate the value of a unidirectional mic versus a clip on omnidirectional one. Heck it's part of the reason I stopped using mechanical keyboards as I wanted to keep using my Fidelio X1s for gaming but the lapel mic was picking up my keyboard way too much over skype which was quite annoying. Also for those using speakers and headphones about equally like I do it's also quite nice for cabling purposes to not have to unplug stuff continuously, as well as some hassle involved in using the same set of headphones for almost everything you do.
Sure you can get better audio quality for less but there are plenty of arguments for headsets, it's a bit tiresome hearing complaints about value for money in every single discussion of headsets.
Personally I think with headphones it comes down to personal taste, I've tried really expensive headphones and mid'ish range cans and sometimes some of the mid range ones sounded as good to me as the really high end stuff :)
