First Build Gaming PC help please..
do i go for it over the BeQuiet Pure Power L8 500W '80 Plus Bronze' Power Supply - With 120mm Silent Wing Fan Built in or XFX 550W 80+ Bronze Certified ATX Power Supply
Yes you do, its price is excellent and it also makes the shipping cost cheaper here at OcUK.
YOUR BASKET
1 x Gigabyte Z97X-SLI - Devils Canyon Core i5 4690K Bundle **£14 Saving** £264.58
1 x NZXT Hale Power 90+ 550W '80 Plus Gold' Power Supply £43.99
Total : £322.67 (includes shipping : £11.75).
YOUR BASKET
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £46.99
Total : £321.17 (includes shipping : £8.00).
As you can see the total is lower despite the NZXT costing less.
YOUR BASKET
YOUR BASKET
Wow, I never noticed that either haha, despite being the same units inside exactly the packaging must be considerably heavier or something
I would pay the £1 extra for the modular cables on the NZXT unit however :cool:
The golden greece isn't modular, NZXT is
ignore
Its not modular, honestly you are starting to get annoying.
Hmm, I always thought it was - description and google images say different!
"Flat modularized cables provide easy cable management while leading to better airflow."
Sorry though!
Ignore
Sorry though!
Only the 650W and up are semi-modular, what you have posted is a picture of the 750W version as clearly visible on the label.
Here is a 550W version,
pretty much going to go with this, maybe change a few things but to similar cheaper options if i find any
Sapphire Radeon R9 270X Boost OC 2048MB GDDR5 PCI-Express Card £129.95
AOC E2470SWDA 23.6" Widescreen LED Monitor - Black £104.99
Kingston HyperX 8GB (2x4GB) PC3-17100C11 2133MHz Dual Channel Kit - Black/Red (HX21C11BRK2/8-OC) £67.99
Gigabyte Z97P-D3 Intel Z97 (Socket 1150) DDR3 ATX Motherboard £65.99
Intel Pentium K Anniversary G3258 Socket LGA1150 Processor - Retail £52.99
Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £38.99
Antec One Gaming Case - Black £29.99
Raijintek Themis Direct Contact CPU Cooler £17.99
total - £572.36
anything else do i need for building this? got an anti-static wristband already
You might want to add a DVD drive to that, if you were planning on installing Windows from a disc you can do it from a USB stick, but if you preferred a disk drive is only about £12
I'm not sure whether the motherboard comes with 3 SATA cables, if not you might want to buy another one for the disk drive or simply unplug it when not in use and put it into your hard drive
i have a disk drive from my old broken PC just hope it works, was planning on installing off USB i already have one with windows 7 on and that works ill just wipe it and put windows 8 on though, i might use one from my old PC if thatll work if not buy an extra one if needs be, thanks for the help! much appreciated
Sounds good, I'd stick with the USB if I were in your position. Is your old disk drive IDE or SATA (does it have a long ribbon-type connector to the motherboard or a small plug?) If it's IDE, it won't work with your new motherboard
Should do, SATA cables are pretty much all the same
Only difference generally is that the SATA 3 revisions have little clips on to lock it into place, nothing else I don't think :)
