Sandybridge upgrade worth it?
Permabanned
6 Sep 2011
I have a sandy bridge 2500k cpu, 8gb ram and amd 6950 gpu
I was thinking of upgrading when the haswell-e comes out... but was wondering if it would be worth it. I wanted to get an i7 as I have started rendering a lot of videos for my youtube channel and it does take a good hour to render an hour video.
I have also started to see my gpu lacking... although its still quite good.
Do you think the haswell-e refresh will be worth it? or how about the x99's. I don't know too much about these cpu's, so if anyone could give some advice on when i should upgrade.
It should be worth the upgrade seeing as your CPU is coming up on four years old. Haswell-e looks promising, X99 is no doubt going to be very expensive though.
Z68A-GD65
my heart was set on an decent i7 due to rendering to be honest... but just wondering whether itd be worth it now with the performance gains, later with the haswell e or wait a bit longer for the x99's
hmmm why whats the estimated prices on the x99's
looks like it will be the haswell-e then
You'll also have to think about RAM prices, X99 will be using DDR4. The current OcUK prices are apparently going to go down, but still I think DDR4 will be expensive at first. For a cheap upgrade, as RJC said, a 26/2700k or 3770k with a BIOS flash will be excellent for rendering (for now). It entirely depends on whether you will have the funds for the X99 platform when it's released?
do x99 cpu / boards exclusivlty use ddr4? its not backwards compatible with DDR3?
