Hello, forum fellows, I'm about to build my 3rd gaming rig, one that will be ultra-portable, including lan parties and airport and such, and I realized that I need your help/expertize.
My build will look something like this:
MB: Asus Maximus VI Impact
CPU: Intel i5 4670k
Cooler: Deepcool Gamer Storm Gabriel
SSD: 2x Intel SSD 180GB S-ATA 3
RAM: 16GB 2x Avexir Core Series 8GB DDR3 1600mhz 1.5v Blue led
VGA: Asus GTX 760 Direct CU II Mini
Case: Lian LI PC-TU100
PSU: Silverstone SFX Strider 450W Gold modular supply + modular slim cables
+ peripherals
Now, my already bought components are the ones in Bold.
I found the PSU on oc uk and cable set but no trace of the GPU, case, and cooler.
Now could you guys recommend/suggest whether there's a better cooler that will fit in such a tiny case and with the Maximus Impact Mobo?
also, where can I find the cheapest msi 760 mini or asus 760 mini,
and where I could order my case from.
Also , if you should bring about any other suggestion of case/psu/gpu/cooler that will be very small and easy to carry around (i would have even considered EVGA Hadron Air if it had a handle (I don't reckon it's that much bigger).
So if I should change the case, the whole psu/gpu/cooler scenario changes as well.
Please advise!
Sneak preview:
CPU: Intel i5 4670k
+ peripherals
Please advise!
Sneak preview:
