NVIDIA GeForce GTX 870 “Maxwell” Specifications Analysis – 13 SMM Units With 2nd Generation 1644 CUD
At £250 I may just be tempted by an upgrade. A reasonable upgrade over a 680, but I was hoping for better performance.
or I may just wait for the inevitable £700 monster that will be released next year.
http://www.3dmark.com/3dm11/8604885
I ran 3DMark11 on a Titan clocked at 1032Mhz (locked clocks) for comparison. 1k points more than the leaked slides. It would be cool of someone with a 780 would run it on stock clocks.
Is that a typical titan oc? I'm thinking of picking one up if I can as there should be no VRAM limit going forward.
These new cards seem like they will struggle sooner than the 780/titans like my 680 is starting to.
Not even close. On stock BIOS, 1200Mhz is nice and 1150Mhz should be doable (my bad bad card does 1150Mhz). As for a custom BIOS, 1250Mhz is very easy with a little addition in voltages :)
Here you go guys.
ScoreP12840 with NVIDIA GeForce GTX 780(1x) and Intel Core i7-4790K
Graphics Score
13911
Physics Score
10538
Combined Score
10276
Thats a totally stock system, even ram is knocked down to 1333mhz. My card runs at 1097/3305 at stock including core boost.
Here you go guys.
Graphics Score
13911
Physics Score
10538
Combined Score
10276
So about 600 points higher than the supposed leaked slides. Thanks for running that :)
It is definitely slower than a stock 290X, I have just run it and even with me browsing the internet in the background it was not close.
I also think that the slides are fake as they have covered parts of GPUZ that does not need it.
And then some.
290 (none X) at Reference clocks 947/1250 GPU Score = 14149. 6 or 7% faster http://www.3dmark.com/3dm11/8604967
@ 1032/1400 GPU Score = 15330 http://www.3dmark.com/3dm11/8604995
Clock for Clock about 8% faster than a GTX Titan, i'm genuinely surprised at that.
Well not long to wait for something official by all accounts and interesting points are what OC headroom will it have and will it be fully DX12 compatible. It is looking like this mid-range card has the makings of a powerful beast.
@ Humbug
You should beast your 290 and add your score to the 3DMark11 thread. :)
Meh....
First Tonga...
Now this...
We'll have to see if any of this is actually true though, as it could be just some dodgy PR campaign from fanboys anyway. I'd be very surprised if the 870 has the specs stated for a start.
As I posted earlier the numbers stack up saying it is a K6000 card, if they are selling those for £250 to £300 they are going to shift a lot.:D
Agreed. I tend to take WCCFTech with a pinch of salt and at times they are right and others, a mile off and more often the latter, however, if these stats are close to being correct and the price is ~£250, it does look like a worthwhile upgrade for guys still on 5xx/6xxx GPUs.
Something else that looks dodgy about the slide is the clockspeed on the CPU, no one runs a gaming/review rig that slow. If they are running a pro card the CPU clockspeed makes more sense.
