** FREE KINGSTON 60GB SSD!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
With qualifying XFX purchases! :D
Kingston 60GB SSDNow V300 Drive SATA 6Gb/s 3 2.5" (7mm height) Solid State Hard Drive - (SV300S37A/60G) @ £41.99 inc VAT
Kingston's SSDNow V300 solid-state drive is a cost-efficient performance upgrade that revives your personal computer and makes it more responsive. It's 10 times faster than a 7200RPM hard drive plus more reliable, more durable and shock-proof, with no moving mechanical parts. It features an LSI® SandForce® controller customised for Kingston and best-in-class components that are affordable for first-time SSD owners. SSDNow V300 is available in kits with all the accessories needed for an effortless transition to the latest technology for less than the cost of a new system. For added peace of mind, it's backed by a three-year warranty, free technical support and legendary Kingston® reliability.
Features:-
- Improves speed of loading applications and system boot up
- No moving parts, solid-state drives are less likely to fail than standard hard drives
- Design optimised to make migrating to an SSD more a ordable
- All-in-one kits with all the components for easy installation
- Multiple capacities to fit your workload
- 2.5-inch drive available in 7.0mm with adapter to fit in 9.5mm systems
- Cool and silent operation
Specification:-
- Form factor: 2.5" SATA
- Capacity: 60GB
- Controller: SandForce SF-2281
- Maximum Read: 450MB/sec
- Maximum Write: 450MB/sec
- Random 4k read/write: 85,000/60,000 IOPS
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- Warranty: 3 Years
Only £41.99 inc VAT - FREE WITH BELOW XFX CARDS!!
ORDER NOW
XFX Radeon R9 290X DD Black Edition 4096MB GDDR5 PCI-Express Graphics Card (R9-290X-EDBD) @ £389.99 inc VAT
For gamers who demand the very best, AMD Radeon™ R9 290X graphics shatters ordinary GPU performance. Groundbreaking GCN Architecture pushes your performance to insane levels while AMD TrueAudio technology and ultra-resolution gaming take you even deeper into the action.
XFX's exclusive Black Edition graphics card are the most rigorously tested graphics card. They are pre-overclocked to the maximum core clock achievable and come from the highest quality yield GPUs which make up the top 1% of those produced in the world. In addition, we pair it with the highest quality components to ensure there are no bottle necks so you can be certain you are getting the best graphics card possible on the market today.
XFX's exclusive ghost thermal 2.0 design creates a floating heatsink with open airflow between the PCB and the cover so that air can quickly ventilate off the card while simultaneously cooling the core process and the components. We've also made major advances from our first generation which includes a heat tested light weight plastic to create an overall lighter thermal which reduces the physical strain on your gpu.
XFX's exclusive dual fan double dissipation design utilizes two larger fans which run at slower RPM than comparable single fan soltuions which must run at much higer RPMs just to barely achieve the same cooling needs. Because of this design, XFX is able to achieve up to 13db lower noise than the competitor while simultaneously increasing the overall cooling by 7°C.
Specification:-
- GPU: Hawaii Pro
- Stream Processors: 2816
- ROPS: 64
- Core Speed: 1050MHz
- Memory Speed: 5000Mhz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- PCI-Express X16 lane required
- 600W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Card Dimension (cm) : 29.5 x 14.3 x 4.2
- Card Dimension (inch) : 11.61 x 5.63 x 1.65
- Warranty: 2yr
Only £389.99 inc VAT.
ORDER NOW
XFX Radeon R9 290 DD Black Edition 4096MB GDDR5 PCI-Express Graphics Card (R9-290A-EDBD) @ £289.99 inc VAT
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
OcUK has negotiated special RMA terms with XFX which allows OcUK to express RMA any XFX item purchased from ourselves within 48 hours. Also exclusive to OcUK we allow the removal of the stock cooler for those wishing to water-cool their XFX product or change the cooler.
Specification:-
- GPU: Hawaii Pro
- Stream Processors: 2560
- ROPS: 64
- Warranty: 2yr
Only £289.99 inc VAT.
ORDER NOW
XFX Radeon R9 280X DD Black Edition 3072MB GDDR5 PCI-Express Graphics Card (R9-280X-TDBD) @ £227.99 inc VAT
XFX R9 280X has the performance to power the latest games with ease but at a very aggressive price point making it incredible value for money.
Specification:-
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Core Clock Speed: 1080MHz
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 6200MHz
- Load / Idle Board Power: <300W / <3W
- Display Outputs: 2x DVI + 1x DP + 1x HDMI
- Power: 250W TDP
- 2yr Warranty
Only £227.99 inc VAT.
ORDER NOW
XFX Radeon R9 280 DD Edition 3072MB GDDR5 PCI-Express Graphics Card (R9-280A-TDFD) @ £169.99 inc VAT
XFX R9 280 has the performance to power the latest games with ease but at a very aggressive price point making it incredible value for money.
Specification:-
- Core Clock Speed: 933MHz
- Stream Processors: 1792 ALU
- Memory Width / Speed: 384 bit / 5000MHz
- Power: 250W TDP
- 2yr Warranty
Only £169.99 inc VAT.
ORDER NOW
A great SSD for FREE with above XFX purchases!!
That's a good deal, better than here have some games that you probably don't want anyway.
Actually even better as you get the games voucher as well. :cool:
Hhmmm wasent the r290 about £255-265 before? ;)
Last week a few of the XFX cards were on the week deals section at those prices.
I missed out because I was umming arring too much but looks like this SSD will sweeten the sufficiently for an order :D.
Edit: Actually, looking at the R9 280 which is what I was considering. Someone has just pointed out the price has gone from £155 (reduced to £150 in the sale) to £170 after the sale ended. Hmm.
Sell the SSD for £30 and you have the card you want at £140. :)
It is good value for money and you'll likely have an order from me soon. However, I feel it's somewhat misleading/deceptive to say it is free when the price has increased.
