** CELEBRATING CASEKING's 7th YEAR @ GAMESCON WITH EPIC DEALS!! (WEEKEND ONLY) **
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
First of all babes:-
Meet some of our colleagues, Caseking crew:-
10505280_10152607588377230_4438007082569468716_n.jpg~original
So to celebrate Caseking's 7th year at Gamescon and our further expansion in Hungary yes that means we now have footholds in UK, Germany, Hungary, Poland, France and Taiwan. World wide domination will be ours! :D
LET THE DEALS COMMENCE ON OcUK/CASEKING EXCLUSIVE PRODUCTS:
SuperFlower Leadex Platinum 1200W Fully Modular "80 Plus Platinum" Power Supply - Black @ £149.99 inc VAT
Leadex Platinum series PSU are 80+ Platinum certified with 100% fully modular cable design, our R&D team's latest innovation, a brilliant idea to maximize PSU cables & connectors management to have the best cable routing solution, also increase case chassis air flow to have best cooling for your system.
Ledex series PSU provides high efficiency & stable power output and come with a 14cm two-way thermal control intelligent cooling fan to ensure your professional PC system will work under heavy load, also capable of powering your PC system equipped with NVIDIA® SLI™ or ATI CrossFireX™ setup.
Features:
- 100% Full Modular Cabling Design For Easy Cable Management<br />
- 80 PLUS ® Platinum Certified, 91.07% 92.44% 90.47% Efficiency At 20% 50% 100% Rated Load<br />
- Full Range Auto Voltage Detection Design 100V~240V (Active PFC)<br />
- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification<br />
- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation<br />
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection<br />
- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards<br />
- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card<br />
- Patented Easy To Use & Install Crystal Clear Cube Connectors with LED<br />
- More than 2,000 times On/Off test<br />
- Unleaded Green Materials with RoHS/WEEE Compliance<br />
- Perfect For Professional & High Performance Gaming System
Specification:
- Type: ATX <br />
- Maximum Power: 1200W <br />
- Fans: 1 x 14cm <br />
- PFC: Active <br />
- +12V Rails: 1 <br />
- Modular Cable: Yes 100% modular cable design <br />
- Input Voltage Full Ranage - 100V~240V <br />
- Input Frequency Range 50 ± 3 Hz / 60 ± 3 Hz <br />
- Output +3.3V@20A ; [email protected] ; [email protected] ; [email protected] ; [email protected] <br />
- Protection OVP?OCP?OPP?SCP?UVP <br />
- Dimension 200mm(L) x 150mm(W) x 86mm(H) <br />
- 1x 20+4-Pin ATX12V/EPS12V<br />
- 1x 8-Pin EPS12V<br />
- 1x 4+4-Pin ATX12V/EPS12V<br />
- 8x 6+2-Pin-PCIe<br />
- 10x SATA<br />
- 5x 4-Pin-Molex<br />
- 1x Floppy<br />
- Warranty: 5yr
</p>
Was [£179.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 1000W Fully Modular "80 Plus Platinum" Power Supply - Black @ £129.95 inc VAT
Features
- 80 PLUS ® Platinum Certified, 91.12% 92.53% 91.11% Efficiency At 20% 50% 100% Rated Load
- Product Review: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=340
Specification:-
- Type ATX
- Maximum Power 1000W
- Fans 1 x 14cm
- PFC Active
- +12V Rails 1
- Modular Cable Yes 100% modular cable design
- 1x 8-Pin EPS12V
- 6x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Was [£149.99] Inc. VAT
Only £129.95 inc VAT.
ORDER NOW
SuperFlower Leadex GOLD 1000W Fully Modular "80 Plus Gold" Power Supply - Black @ £109.99 inc VAT
Leadex series PSU are 80+ Gold certified with 100% fully modular cable design, our R&D team's latest innovation, a brilliant idea to maximize PSU cables & connectors management to have the best cable routing solution, also increase case chassis air flow to have best cooling for your system.
Features:-
- 80 PLUS ® Gold Certified, 90.43% 92.03% 90.27% Efficiency At 20% 50% 100% Rated Load
Speciication:-
- Type: ATX
- Maximum Power: 1000W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- Output +3.3V@24A ; [email protected] ; [email protected] ; [email protected] ; [email protected]
- 1x 8-Pin EPS12V
- 8x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Was [£129.95] Inc. VAT
Only £109.99 inc VAT.
ORDER NOW
SuperFlower Leadex GOLD 750W Fully Modular "80 Plus Gold" Power Supply - Black @ £74.99 inc VAT
Features:-
Speciication:-
- Type: ATX
- Maximum Power: 750W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- 1x 8-Pin EPS12V
- 4x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Was [£86.99] Inc. VAT
Only £74.99 inc VAT.
ORDER NOW
SuperFlower Golden Green HX 650W "80 Plus Gold" Power Supply - Black @ £55.99 inc VAT
The Golden Green HX series are the perfect all rounder. They meet 80+ Gold Standards resulting in lower electricity usage, saving on the bills, hence the green. The Gold Rating means they are capable of powering pretty much any PC specification and the 14cm fan ensures the PSU stays cool whilst remaining quiet. One of our best value for money Gold Rated power supplies we sell.
Features:-
- Supports all Intel and AMD Dual Core and Quad core and its compatible Motherboards, ATX/BTX compliant.
- Supports Intel Core i7-980X / Core i7 / Core i5 / Core 2 Quad / Core 2 Duo &AMD Phenom II X6 / Phenom II X4 / Phenom II X3 / Athlon 64 X2series chip set.
- EPS 12V Ver2.92
- Patent black color connector, easy plug-in design, safe and firmly attached.
- Fit in with EuP(Energy-using Products) instructions / U.S.A Energy Star standards: energy consumption during shut off status less than 1W
- PCI-E power plugs are setup in a 6+2 configuration for the latest graphic cards and Compatible with every brand.
- Patent 14cm LED Low Noise Fan, Great air flow for exceptional heat dissipation.
- Passed 80 PLUS® Gold Certification, on 20% 50% 100% loading, with 91.64% 92.88% 90.99% Transform Efficiency.
- Full Range APFC, support 100V~250V.
- Patent high power and low consumption transformer / Patent dual voltage circuit with intelligence thermal control system (Patent applying for U.S.A, Taiwan, Mainland China and other countries)
- Solid state Capacitance is used for longer lasting and higher reliability.
- Extend Output Capacitance are used for higher stability and longer lasting.
- Switches on/off test for more than 2000 times.
- Multiple safety certificates acquired.
- All series are made of RoSH unleaded green material.
Specification:-
- Real Power: 650W
- Transform Efficiency: on 20% 50% 100% loading, with 88.77% 92.82% 88.61% Transform Efficiency
- Intel Power Design Guide: EPS Ver. 2.92
- Outlook: Honeycomb ventilation panel, high efficiency air flow design
- Fan Size: 14cm Silent Fan with temperature control
- Dimension: 145mm(L) x 150mm(W) x 86mm(H)
- Protection: OVP?OCP?OPP?SCP?UVP
- Safety Certificates: BSMI R33529 / CE / FCC / CUL / cTUVus / CB
- 1x 8-Pin EPS12V
- 4x 6+2-Pin-PCIe
- 8x SATA
- 4x 4-Pin-Molex
- Warranty: 5yr
Was [£67.99] Inc. VAT
Only £55.99 inc VAT.
ORDER NOW
Avexir Core White Series 16GB (2x8GB) DDR3 PC3-17200C11 2133MHz Dual Channel Memory Kit (AVD3U21331108G-2CIW) - White Light @ £119.99 inc VAT
Avexir Core Series is designed specifically for the extreme power users who focus on challenging the excellence in high performance gaming experience. The Core Series is developed by Avexir R&D team with 10+ years’ experience of researching in memory core technology and designed specifically for the power users and gamers who demand ultimate performance and extreme reliability gaming modules.
Avexir strictly adheres to quality standards set by JEDEC (the Joint Electron Devices Engineering Council) and ISO9001.
With 100% hand-tested extensively in multiple PC major-brand motherboard environments at its rated speed, Avexir makes sure that both stability and performance of every memory module reach the highest quality criteria.</p>
Features:
- Black PCB<br />
- Black high performance heatspreaders<br />
- White LED Strobe lighting effect (See product images)<br />
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.<br />
- CAS Timings: 11-11-11-31<br />
- Dual Channel Kit: (2x8GB)<br />
- 100% tested at 2133MHz in Intel & AMD based motherboards<br />
- Lifetime Warranty<br >
- Haswell compatible<br />
- Piledriver compatible</p>
Was [£139.99] Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Avexir Core White Series 8GB (2x4GB) DDR3 PC3-17200C11 2133MHz Dual Channel Memory Kit (AVD3U21331104G-2CIW) - White Light @ £65.99 inc VAT
Features:
- Black PCB<br />
- CAS Timings: 11-11-11-311<br />
- Dual Channel Kit: (2x4GB)<br />
Was [£79.99] Inc. VAT
Only £65.99 inc VAT.
ORDER NOW
Avexir Venom Series 16GB (2x8GB) DDR3 PC3-17200C11 2133MHz Dual Channel Memory Kit (AVD3U21331108G-2CIG) - Green Light @ £119.99 inc VAT
Avexir Venom Series is designed specifically for the extreme power users who focus on challenging the excellence in high performance gaming experience. The Venom Series is developed by Avexir R&D team with 10+ years’ experience of researching in memory core technology and designed specifically for the power users and gamers who demand ultimate performance and extreme reliability gaming modules.
Avexir Core Venom Series is extremely unique as its most likely the only RAM in the world which uses strobe/pulsating LED's. Even more unique is that the Venom series are green in colour, making them look absolutely amazing, plus a perfect match for Gigabyte Sniper boards.
Features:
- Black PCB<br />
- Green LED Strobe lighting effect <br />
- Lifetime Warranty</p>
ORDER NOW
Avexir Venom Series 8GB (2x4GB) DDR3 PC3-17200C11 2133MHz Dual Channel Memory Kit (AVD3U21331104G-2CIG) - Green Light @ £65.99 inc VAT
Features:
- Black PCB<br />
ORDER NOW
Avexir Gold Series 8GB (2x4GB) DDR3 PC3-17200C11 2133MHz Dual Channel Memory Kit (AVD3U21331104G-2CEY) - Yellow/Gold Light @ £65.99 inc VAT
Avexir Gold Series is designed specifically for the extreme power users who focus on challenging the excellence in high performance gaming experience. The Gold Series is developed by Avexir R&D team with 10+ years’ experience of researching in memory core technology and designed specifically for the power users and gamers who demand ultimate performance and extreme reliability gaming modules.
Avexir Core Gold Series is extremely unique as its most likely the only RAM in the world which uses strobe/pulsating LED's. This Gold series features gold heatspreaders along with yellow/gold coloured strobe lights, a perfect match we feel in any motherboard with gold-yellow/back theming such as Asrock and Asus Haswell mainboards.
Features:
- Black PCB
- Gold/Black high performance heatspreaders
- Gold/Yellow LED Strobe lighting effect
- Lifetime Warranty
ORDER NOW
Avexir Core Red Series 16GB (2x8GB) DDR3 PC3-17200C11 2133MHz Dual Channel Memory Kit (AVD3U21331108G-2CIR) - Red Light @ £119.99 inc VAT
Avexir strictly adheres to quality standards set by JEDEC (the Joint Electron Devices Engineering Council) and ISO9001.</p>
Features:
- Black PCB<br />
- Red LED Strobe lighting effect (See product images)<br />
ORDER NOW
Avexir Core Blue Series 8GB (2x4GB) DDR3 PC3-17000C11 2133MHz Dual Channel Memory Kit (AVD3U21331104G-2CI) - Blue Light @ £65.99 inc VAT
Features:
- Black PCB<br />
- Blue LED Strobe lighting effect (See product images)<br />
- Sandybridge compatible<br />
- Bulldozer compatible</p>
ORDER NOW
TeamGroup Xtreem LV "Frost Edition" 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Kit @ £65.99 inc VAT
Team Xtreem LV is the most popular overclocking and gaming gear in the LAN party. Based on the memory architecture evolution on Intel Core i7, Team raises the frequency of the Xtreem LV DDR3 by 20% from 2000MHz to 2400MHz. Also, by continuing the high frequency and low latency tradition of the Xtreem LV memory, the Xtreem LV DDR3 2400 can fully display the configuration 10-12-12-31 (tCL-tRCD-tRP-tRAS) at a low operating voltage at 1.65V without sacrificing either performance or stability. All these have witnessed the extraordinary R&D capacity and capability of Team. In addition to the unchanged genuine chip policy, Team ensures chip quality with the exclusive sorting technology to screen chips. In order to further ensure the optimal performance and flawless quality of the Xtreem LV DDR3 2400, Team applies the 24-hour burn-in test and industry-approved MemTest software to perform the OQC inspection of all modules before shipping to assure the stability and exceptional performance of every Xtreem LV DDR3 2400. The Xtreem LV DDR3 2400 from Team has a conventional 8-layered PCB design and is covered with the X-mark heat-sink labeled for the Xtreem series. In addition to the clean appearance as found in all Team Xtreem memory modules, a groove has been added to the heat-sink for power users to install fans on top to enhance ventilation. For more information on this product, please visit the Team Group website at: www.teamgroup.com.tw.
Features:-
- Black PCB
- White Heatspreader
- Module Type 240Pin Unbuffered DIMM Non ECC
- CL-tRCD-tRP-tRAS 10-12-12-31
- DRAM Density 128x8 / 256x8 / 512x8
- Data transfer bandwidth 19,200MB/Sec (PC3 19200)
- Heat Sink Aluminum heat-sink
- Working voltage 1.65V
- Warranty Lifetime warranty
- Note Intel XMP1.3, compatible with series Intel 7 chipsets and higher.
ORDER NOW
TeamGroup Xtreem LV "Frost Edition" 16GB (2x8GB) DDR3 PC3-19200C10 2400MHz Dual Channel Kit @ £109.99 inc VAT
Features:-
- Black PCB
ORDER NOW
TeamGroup Xtreem LV 8GB (2x4GB) DDR3 PC3-21300C11 2666MHz Dual Channel Kit (TXD38G2666HC11CDC01) @ £67.99 inc VAT
Team Group Inc. has once again led the industry and released the world’s limited dual-channel Xtreem DDR3 2666. Intel’s latest Series Z77 chipsets. As it adopts strictly selected chips from original factories and has to pass through stringent tests and verification procedures, it is able to enhance even further its support capabilities after teaming up with the latest Intel XMP V1.3 version. In addition, it is also collocated with eight-layer PCB in order to increase its stability performance by up to 16GB (4GBx4) large capacity. Its built-in ultra-high clock design is able to allow the computer operation to reach an unimpeded speed.
Features:-
- CL-tRCD-tRP-tRAS 11-13-13-35
- DRAM Density 256x8
- Data transfer bandwidth 21,328MB/Sec (PC3 21300)
- Heat Sink Yes
Was [£89.99] Inc. VAT
Only £67.99 inc VAT.
ORDER NOW
Powercolor Radeon R9 290 PCS+ OC 4096MB GDDR5 PCI-Express Graphics Card with FREE AMD 8GB 2400MHz Memory Kit @ £299.99 inc VAT
PCS+ Version features Powercolor's amazing tri-fan cooler, for much lower noise levels whilst offering superior cooling. Along with a great overclock out the box, this card runs at 1040MHz core and 5400MHz memory.
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:
- Radeon R9 290</b> <br />
- GPU: Hawaii Pro <br />
- Litecoin Hash Rate: 800-950 <br />
- Stream Processors: 2560 <br />
- Core Speed: 1040MHz <br />
- Memory Speed: 5400Mhz <br />
- Memory interface: 512-Bit <br />
- Memory capacity: 4096MB GDDR5 <br />
- Cooling: 2-Slot Blower Fan <br />
- PCI-Express X16 lane required <br />
- 750W or greater PSU required <br />
- Power Connectors: 8-pin + 6-pin required <br />
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort <br />
- Warranty: 2yr
Was [£305.99] Inc. VAT
Only £299.99 inc VAT - WITH FREE 8GB 2400MHz Memory Kit
ORDER NOW
Powercolor Radeon R9 290X PCS+ OC 4096MB GDDR5 PCI-Express Graphics Card with FREE AMD 8GB 2400MHz Memory Kit @ £359.99 inc VAT
PCS+ Version features Powercolor's amazing tri-fan cooler, for much lower noise levels whilst offering superior cooling. Along with a great overclock out the box, this card runs at 1050MHz core and 5400MHz memory.
AMD Radeon R9 290X is a new graphics card powered by the latest AMD Radeon™ R9 290X graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:
- Radeon R9 290X</b> <br />
- GPU: Hawaii XT <br />
- Litecoin Hash Rate: 850-1000 <br />
- Stream Processors: 2816 <br />
- ROPS: 64 <br />
- Core Speed: 1050MHz <br />
- Fan Speed: 20% - 40% (Quiet Mode) & 20%-55% (Uber Mode) <br />
- Comes with BF4 Voucher included in the box <br />
- Warranty: 2yr
Was [£389.99] Inc. VAT
Only £359.99 inc VAT - WITH FREE 8GB 2400MHz Memory Kit
ORDER NOW
Sapphire Radeon R9 290X Vapor-X OC 8192MB GDDR5 PCI-Express Graphics Card **OcUK WorldWide Exclusive** @ £599.99 inc VAT
OcUK has a worldwide exclusive on the only 8GB 290X in existence, but this is not any 290X it's a highly fine tuned machine being the Vapor-X edition with near silent cooling solution. Running with a 1060MHz core clock and with memory clocked at 5600MHz makes this card absolutely perfect for a 4K setup, even more so with a pair or three of these in Crossfire. That means you could play games like Skyrim with expansion packs at 4k resolution and still not run out of VRAM.
Based on the award-winning Graphics Core Next (GCN) architecture from AMD with 2816 Stream Processors, the SAPPHIRE R9 290X Vapor-X is an Overclocked edition which boasts 8GB of the latest GDDR5 memory running at 1400 MHz (5.60GB/s effective) and high speed engine clocks of 1060MHz.
SAPPHIRE’s innovative Vapor-X cooling technology allows products to run not only cooler but also much quieter. A Vapor-X product means a virtually silent gaming experience and more headroom to explore performance tweaking!
Choke is an important component of the graphics card. By working with the component engineer, Sapphire’s patent pending choke is 10% cooler and offers 25% more power efficiency than a normal choke. The graphics card will be more reliable and save energy.
Improved reliability and better overclocking are possible by using only high-polymer, aluminum capacitors which posses far superior characteristics than regular aluminum capacitor for a longer product life. When operational temperatures drop by 20°C, the product life span is extended by a factor of ten, when the operational temperature increases by 20°C, the product life span only decreases by 10%.
Along the edge of the card the PCB is extended and one of the copper layers left exposed. An additional heatsink mounted directly to this copper layer allows heat absorbed into the PCB from the GPU and other components to be transferred to the heatsink and cooled by the airflow. This feature alone can reduce core temperature by 2 degree C.
Specification:-
- GPU: Hawaii XT
- ROPS: 64
- Core Speed: 1060MHz >
- Memory Speed: 5600Mhz
- Memory capacity: 8192MB GDDR5
- 600W or greater PSU required
- Power Connectors: 2x 8-pin required
- Warranty: 2yr
Was [£629.99] Inc. VAT
Only £599.99 inc VAT - WITH LOADS OF FREE GAMES!
ORDER NOW
AOC G2460PG 24" Widescreen G-Sync 144Hz 1ms Gaming LED Monitor - Gunmetal @ £337.99 inc VAT
The AOC G2460PG display combines stylish design with high-performance features that will impress the most demanding gamers. From first-person shooters to high-speed racing games, you’ll never miss out on the action with 1 ms response time for blur-free images. This 24-inch display with Full HD resolution offers sharp, stunning picture quality with typical 1000:1 contrast ratios. The integrated DisplayPort connector and five USB hubs are ideal for hooking up a range of devices and peripherals, plus USB 3.0 technology offers super-speed charging and data transfer. The ergonomic stand offers hours of viewing or gaming comfort, allowing you to adjust the height, tilt and swivel, as well as pivot into portrait mode. No matter what you’re doing, smart energy-saving functions like W-LED backlighting help reduce your power consumption.
Specification:-
- NVIDIA G-Sync Technology
- Monitor Size: 24"
- Visible Screen Size: 61 cm
- Screen Format: 16:9
- Brightness: 350 cd/m² (typ)
- Contrast Ratio Dynamic: 80.000.000:1
- Contrast Ratio Typical: 1000:1
- Pixel / Dot / Pitch: 0.276 (H) x 0.276 (V)
- Display Area: 531.36 (H) x 298.89 (V)
- Viewing Angle: 170°/160° (CR 10)
- Response Time: Up to 1 ms GtG
- Maximum Resolution: 1920 x 1080@144 Hz (DVI Port)
- Recommend Resolution: 1920 x 1080@144 Hz
- Colors: 16.7 M
- HDCP compatible: yes
- Inputs: DisplayPort
- Dimensions (WxHxD): 565.4 x 393.6 (+130) x 244.58 mm
- Warranty: 3yr
Was [£347.99] Inc. VAT
Only £337.99 inc VAT.
ORDER NOW
EIZO Foris FG2421 23.5" 240Hz Widescreen Gaming LED Monitor - Black/Red @ £299.99 inc VAT
Experience fluid gameplay free from motion blur with the gaming industry’s first 240 Hz monitor. EIZO’s Turbo 240 converts 120 Hz input signals to 240 Hz for a refresh rate double that of conventional gaming monitors so you can enjoy the smoothest motion display yet for first-person shooter, racing, and other fast-action genres.
Input lag, or the time it takes for commands from a keyboard, mouse, or controller to appear on the screen, can be the difference between hitting your target and missing it. EIZO developed its own integrated circuit to ensure your commands appear onscreen without delay.
Play like the pros with gaming presets from pro gamers such as Counter-Strike legend Patrik “cArn” Sättermon and Dota 2 player Johan “n0tail” Sundstein. Use the bundled software, ScreenManager Pro for Gaming, to download these and other presets from gaming.eizo.com or to export your own presets.
The FORIS FG2421 uses a new VA (vertical alignment) panel with a native contrast ratio of 5000:1. This is 5 times more than what other gaming monitors offer and increases the visibility in dark scenes so you can spot enemies more quickly.
The rear cabinet design features an LED backlit EIZO logo on a glossy surface surrounded by a vermillion frame. The logo glows brilliantly in a dimly-lit room or in a tournament setting. The front cabinet has a simple design so you can focus on the screen.
EIZO’s five-year warranty is two years or 67% longer than the standard three-year warranty of most brands.
Specification:-
- Panel Type: VA
- Size: 23.5" / 59.8cm (598mm diagonal)
- Native Resolution: 1920x1080 (16:9 aspect ratio)
- Display Size (HxV): 521.3 x 293.2mm
- Pixel Pitch: 0.272 x 0.272mm
- Grayscale Tones: 256 tones (a palette of 1021 tones)
- Display colours: 16.77 million from a palette of 1.06 billion
- Viewing Angles: 176 / 176
- Brightness: 400cd/m (Turbo 240: off)
- Contrast ratio: 5000:1 Typical (15000:1 with Contrast Enhancer)
- Response Time: Less than 1ms (Turbo 240: ON, Monito spec)
- Connections: 1x DisplayPort, 1x DVI-D (with HDCP) & 1x HDMI
- USB Hub: 2 Ports
- Power Saving: Less than 0.5W
- Standby Mode: Less than 0.5W
- Stand: 60mm Height adjust, 25 degress up tilt and 344 degrees swivel
- Dimensions: 563.5 x 391 - 451 x 200 mm
- Weight: 6.2kg
- Warranty: 5yr
- TFT Central Review: http://www.tftcentral.co.uk/reviews/eizo_fg2421.htm
Was [£359.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
LG Flatron 34UM95-P 34" WideScreen Super-Wide LED Monitor @ £769.99 inc VAT
The UltraWide 21:9 aspect ratio makes movies and games more immersive than ever. Need to get some work done, too? All of that UltraWide real estate makes it easy to view multiple documents at the same time, so you don't need to flip back and forth between them.
The 3440X1440 UltraWide QHD display offers amazingly sharp picture quality. Its pixel area is about 1.8 times larger than an UltraWide Full HD 21:9 monitor, and about 2.4 times larger than a Full HD 16:9 monitor. It provides an efficient environment in using Microsoft Office programs showing 47 columns and 63 rows in excel.
sRGB is the standard color space of ideal color reproduction. So, with over 99% coverage of the sRGB spectrum, this LG monitor is a great solution for professional photographers, graphic designers or anyone looking for highly accurate color.
Multitasking doesn't have to mean shuffling back and forth between windows*. With a single click, the 4-Screen Split feature divides the screen into as many as four customizable segments, two-by-two. Now you can see four different windows at the same time.
The Dual Linkup feature allows two compatible portable devices--such as a computer, camera, phone, or Blu-ray player--to be connected to the monitor, and both can be viewed on the same screen simultaneously.
This monitor's Thunderbolt input/output port allows you to connect up to six compatible devices, moving data between them with incredible speed. The two channels of 10-gigabits-per-second throughput in both directions are up to 20X faster than USB 2.0. Thunderbolt is an exciting innovation for both expansion and premium video display.
The DisplayPort digital video interface is used to connect a high-performance video source to a high-resolution monitor. Thanks to its sophisticated design, a DisplayPort cable can also be used to carry audio, USB signals and other data as well.
LG’s LED backlighting delivers exceptional brightness and amazing image clarity. You'll see richer colors and deeper blacks too, and LEDs offer greater energy efficiency compared to conventional LCD monitors.
IPS (In-Plane Switching) technology enhances thA dynamic contrast ratio of 5,000,000:1 is your assurance of strong video performance, with deep blacks, bright whites and pleasing colors.e performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can now view the screen at virtually any angle.
Looking for the ultimate in fine-tuning for your LG monitor? This model is designed to work with compatible calibration devices* that take specific readings and guide you through precise adjustments of color, brightness and more.
Specification:-
- Screen Size Class (diagonal): 34"
- Panel Type: IPS
- Aspect Ratio: 21:9
- Resolution: 3440x1440
- Color Gamut (CIE1931): sRGB 99%
- Brightness (typical): 320 cd/m2
- Contrast Ratio(Original): 1000:1
- Viewing Angle (CR>10): 178/178
- Colour Depth (Num of Colours): 1.07B (8-Bit+FRC)
- Pixel Pitch (mm): 0.2325
- Surface Treatment: Anti-Glare 3H
- Connectivity: 2x HDMI, 1x DisplayPort & 2x ThunderBolt
- Warranty: 2yr
Was [£839.99] Inc. VAT
Only £769.99 inc VAT.
ORDER NOW
Samsung U28D590 28" 4K 60Hz 1ms Gaming Widescreen LED Monitor - Black **OcUK Exclusive** @ £429.95 inc VAT
OcUK will be the first in the UK to get official UK version of this monitor by upto nearly a month. We are expecting our delivery the last week of May. None of our competitors will get stock until mid-end of June as we have an exclusive arrangement with Samsung. This monitor is one of the best 4k displays available and OcUK will have it before any competitor by upto at least two weeks. Pre-order with confidence from ourselves on this stunning Samsung U28D590 28" 4k 60Hz 1ms Gaming Widescreen LED Monitor.
Samsung U28D590 the Main feature of novelty is the resolution 4K (3840×2160), exceeding Full HD (1920×1080) four times. Natural color reproduction with soft color transitions is achieved, in particular, by playlist 1 billion colors. Response time is 1 MS, which perfectly fit to play the game content. Also amongst the peculiarities of the availability of an updated Picture-in-Picture (PIP 2.0). With its help it is possible to reproduce a picture of a small window in the original resolution up to Full HD (1920×1080 pixels) as the main picture is reproduced in UHD. In addition, when playing content small-resolution, innovative function UHD upscale will improve the clarity and quality of the image to the maximum possible resolution of 4K (3840×2160).
The novelty provides connectivity, audio-video devices: include 2 HDMI port and one interface connector Display Port. It is worth noting that the monitor can be connected at once two PC and play back content from both devices without any loss of quality, resolution images with each PC will 1920×2160. This monitor can be easily connected Xbox or PlayStation 4 via the HDMI.
Specification:
- Size with stand (W x H x D ) : 660.9x486.3x169.4 (mm)<br />
- Without stand (W x H x D ): 660.9x410.0x64.7 (mm)<br />
- Packaging (W x H x D ): 794x452x109 (mm)<br />
- Display Screen Size: 28" (70.8cm)<br />
- Aspect ratio: 16:9<br />
- Panel Type: TN<br />
- Brightness: 300cd/m2<br />
- Contrast Ratio: 1000:1 (Typ)<br />
- Dynamic Contrast Ratio: 10,000,000<br />
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)<br />
- Response Time: 1ms (GTG)<br />
- Color Support : 1B<br />
- Viewing Angle (H / V ): 170 ° / 160 °<br />
- Connectivity: 2x HDMI (30Hz), 1x DisplayPort (60Hz)<br />
- USB Hub: NO<br />
- Speakers: NO<br />
- Warranty: 2yr
Was [£446.99] Inc. VAT
Only £429.95 inc VAT.
ORDER NOW
Hazro HZ30WiE V2.0 10-Bit 30" LED Widescreen Professional Monitor - Black **CLEARANCE** @ £379.99 inc VAT
**CLEARANCE SALE, BRAND NEW WITH 1yr WARRANTY**
The Hazro HZ30WiE V2 is ideal for graphics and visual media, where professional grade technology meets revolutionary design. The massive 4MP (2560x1600) WQXGA resolution brings a new dimension to on-screen graphics. S-IPS display technology delivers unsurpassed levels of colour saturation. It results in image clarity that allows for colours to be easily differentiated to bring unheard of precision and accuracy in visual reproduction. Wherever you need it most, the Hazro HZ30WiE V2 performs with consistency and clarity to optimise your visual experience. The Hazro HZ30WiE V2 recognises groundbreaking technology without compromising efficiency, whilst tailoring to the needs of the discerning, professional, user. The masterful design outside augments the genius within, with the Hazro HZ30WiE V2 collating top industry-spec innovation with rock-solid dependability to perform when you need it most, time and time again. With the Hazro HZ30WiE V2, you can view perfectly rendered images without compromising on the space you need to take your creation from conception to fruition. View an uncompromisingly crisp, and sharp, output that won't strain your eyes in a resolution and pixel pitch that'll inject life into your work with piercing detail. The Hazro HZ30WiE V2 offers three times the workspace of a standard 19" monitor and 77% more workspace than a 24" [16:9] display - allowing creative freedom and practicality. With quicker access to colour tools, palettes and document windows, the HZ30WiE V2 is proven to increase efficiency and output. Anyone can see the tangible results of being able to view two application windows side-by-side. Whether it's to look at a website and its code simultaneously, or if it's to streamline data-entry processes, the final result will still be improved efficiency - and, in the case of businesses, an impact on their bottom line.
Features:-
- Aluminum Casing
- LCD Panel: 30" WQXGA colour LCD S-IPS active matrix
- Type: 16:10 aspect Ultra wide gamut TFT-LCD
- Bit Depth: HZ30Wie: 10bit 1.07billion Colors
- Viewing area: 641.28 mm (H) x 400.8 mm (V)
- Resolution: 2560 [H] x 1600 [V]
- Pixel Pitch: 0.2505mm x 0.2505mm
- Contrast Ratio: 1000 : 1(Typ.)
- Refresh rate: 59 ~ 60 Hz
- Response Time: 6ms [grey-to-grey]
- Color Gamut: Wide Gamut 117% (CIE 1976) NTSC [100% AdobeRGB and sRGB Coverage]
- Brightness: 370 cd /m² (Center 1 Point)
- Viewing Angle: R/L : 89°/ 89°U/D : 89°/ 89° (178°/ 178°)
- Connectivity: 1x DisplayPort, 1x DVI, 1x HDMI & 1x VGA
- Surface Treatment: Hard coating(3H), Anti-glare treatment of the front polariser
- VESA Hole Configuration: VESA 100x100 & 200x100
- Dimensions: Approx: 690(L) x 445(W) x 65mm(D) (excluding stand)
- Weight: Approx 11 kg before packaging and excluding stand [approx]
- Power Consumption: In Operation: <150W
- DPMS / OFF: <2W
- Energy Saving Mode: VESA DPMS [Display Power Management Signaling]
- Power Input/Output: DC Input: AC 100V-240V, 50~60Hz, DC Output: DC 24V / 6.3A [approx]
- Inputs: 24V DC Jack, 1 x Dual Link DVI-D;
- Accessories: 1 x Dual Link DVI-D Cable; 1 x IEC 3 Pin AC Power Cable;
- 1 x DC Power Adapter; Instruction Manual
- 1yr Warranty
- Read the TFT Central Review here of 8-bit version: http://www.tftcentral.co.uk/reviews/hazro_hz30wi.htm
Was [£399.95] Inc. VAT
Only £379.99 inc VAT.
ORDER NOW
BitFenix Fury 550W Gold Modular Power Supply - Alchemy Cables (BFP-FUR-550G-KSXK-RP) @ £74.99 inc VAT
For a long time, the power supply is one part of the PC that users prefer to remain unseen. These dull, lifeless boxes were made to perform in the background, away from sight. Challenging the status quo, BitFenix set out to make a power supply that not only delivered on a performance level, but also utilized enough design elements to let it stand out in a system build. To that end, BitFenix announces the Fury Power Supply Series. Featuring top quality components like all Japanese capacitors, a killer design aesthetic, and top-notch efficiency, Fury is set to become the new gold standard in semi-modular power supply units.
Starting with the chassis, Fury brings a bold yet sophisticated design to the realm of power supplies. Both top and bottom are adorned with a stamped BitFenix logo, along with a custom aluminum ring accent that exudes an aggressive look no matter which direction you install it. Combined with a quality matte powder-coat finish, Fury is the first PC power supply that's designed to enhance the look of your system.
After taking the modding world by storm with the Alchemy lineup of sleeved cable extensions, BitFenix has brought its one of a kind Nanosleeve braiding to the Fury Power Supply. Each cable that comes with Fury is sleeved with Nanosleeve braiding for excellent flexibility and unsurpassed aesthetics. With Fury, modders will spare their warranties while saving hours of time sleeving their own PSU cables. Best of all, the semi-modular design allows builders to only use the cables they need, reducing cable clutter and improving airflow inside the system. For the boutique modded look with zero effort, look no further than BitFenix Fury.
All of this power is harnessed via several key components and technologies that make Fury a power supply users can rely on day in and day out. To ensure clean output and long life, Fury employs a design that utilizes all Japanese capacitors. Renowned for their quality and longevity, all Japanese capacitors puts Fury in a class above other PSU designs. A 135mm fluid dynamic bearing fan not only helps keep temperatures under control, but does so with minimal noise. Finally, Fury also comes equipped with BitShield Six-Point Protection, a series of safeguards that prevent damage to the PC caused by electrical anomalies, including under voltage, over voltage, short circuit and more. All of this is backed by a five-year warranty so users can use Fury with confidence.
Available in 550W, 650W, and 750W models, BitFenix Fury delivers a trifecta of performance, reliability and aesthetics perfect for today's high octane PC builds.
Specification:-
- Built by FSP, Designed by BitFenix
- Dimensions (WxHxD): 150mm x 86mm x 160mm
- MTBF: 100,000 hours
- Efficiency Rating: 80Plus Gold
- PF Correction: Active
- Operating Temp. 0 - 40°C
- Protection Features: Over Voltage / Under Voltage / Over Current / Short Circuit / Over Temperature / Over Power
- Safety Approvals: CB / TUV / ULOR CUL / BSMI
- 3.3v: 24A
- 5v: 24A
- 12v: 42A
- Total Power: 550W
- 1x 8-pin CPU Cable (8+4+4)
- 4x 8-pin VGA Cable (6+2)
- 3x SATA Cable (quad, dual, dual)
- 1x Molex Cable (triple)
- 1x SATA + Molex (1+1)
- 1x Floppy Adapter
- 4x Standard Screws
- Warranty: 5yr
ORDER NOW
BitFenix Fury 650W Gold Modular Power Supply - Alchemy Cables (BFP-FUR-650G-KSXK-RP) @ £89.99 inc VAT
Specification:-
- 3.3v: 26A
- 5v: 26A
- 12v: 50A
- Total Power: 650W
- 1x Floppy Adapter
- Warranty: 5yr
Was [£109.99] Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
BitFenix Fury 750W Gold Modular Power Supply - Alchemy Cables (BFP-FUR-750G-KSXK-RP) @ £99.95 inc VAT
Specification:-
- 3.3v: 30A
- 5v: 30A
- 12v: 60A
- Total Power: 750W
- 1x Floppy Adapter
- Warranty: 5yr
Was [£119.99] Inc. VAT
Only £99.95 inc VAT.
ORDER NOW
Since OcUK merged with Caseking nearly two years ago OcUK has only got better, more exclusive products, larger product range, better customer service, more deals, improved website, more interaction and marketing plus there is a lot more to come as our company expands. We are now one of the largest players in Europe and are growing year on year with good growth. Watch this space as it will only get better!
So congratulations to Caseking for 11 years in business and 7th year at Gamescon.
H'onwards
H'upwards
:D :D :D :D :D
The "babes" really do cheapen the image.:(
German market is different to the UK and they love it over there as can be seen from the epic crowds. :)
Gamescon is far bigger and far more successful than anything in the UK, so they know what they are doing. ;)
Agreed. Quite possibly it works in the market it's aimed at, but seeing that makes me think less of casekings & ocuk by association to be honest. They've chosen to do that and every brand decision has to be based around both it's immediate business effect and impact on brand image, for me they've failed badly.
Edit: To be clear, I've no idea what is appropriate for the German market - but choosing to share the images on here is the part I find poor. Could have shared plenty of stuff without focusing on that aspect.
Its OCUK though just look at the product images for most monitors. Maybe it sells monitors to teenagers i dont know.
Some good offers by the way.
I think the babes thing is fine, as long as you also show a bunch of half naked guys to balance things out.
Following the above;
The monitor section on the website makes no sense to me, why does it have to have half naked women on every screen? Spec me threads during work time, monitors is just a no-go area.
Caution: Mind the prude gap [.......................................................... ]
Can't beat a bit of female flesh to sell products IMO.
5UB is over there at the moment.
I will message him now.
Im sure he would be delighted to fulfil your request.
at Overclockers UK, we do what we can for our customers!
The reasoning is, traffic to our website is actually over 95% male.
None of the images we use are offensive, zero nudity or sexual innuendo on display, or perfectly suitable for daytime viewing and nothing worse than you'd see on a TV advert or MTV during the day.
22" monitors: 16 models, 8 with females on display.
23" monitors: 14 models, 2 with females on display.
24" monitors: 39 models, 13 with females on display.
25-32" monitors: 58 models, 24 with females on display.
This is hardly all of our monitors, it is infact less than half.
Some of the images are actually manufacturer provided all the others are to good taste, if anyone thinks otherwise we are happy to change anything which might be deemed offensive.
For those asking for hunks, I present you:-
Iiyama Prolite XB2779QS-S 27" AH-IPS Professional Widescreen LED Monitor - Silver/Black @ £379.99 inc VAT
Featuring WQHD (2560 x 1440) resolution, the XB2779QS can display almost 77% more information on the screen than a Full HD display. Users can create their own workspace by displaying and manipulating multiple applications at the same time. The AH-IPS matrix guarantees high performance with accurate and consistent colour reproduction, wide viewing angles and a fast response time. An array of inputs including HDMI, DisplayPort, DVI and VGA connections ensures compatibility across a wide range of mulitimedia devices. The XB2779QS is perfect for demanding users who settle only for the best specifications and modern design.
With true WQHD 2560 x 1440p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen, i.e. over 76% more in comparison to a 1920 x 1080 monitor.
The AH-IPS panel technology guarantees consistent colour reproduction with wide viewing angles and high contrast and therefore it is especially recommended for graphics design and other applications which require colours to be displayed accurately. The response time of the panel allows for smooth playback while watching films and playing games, making the IPS the best all-round technology suitable for both business and home use.
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals.
A Height Adjustable Stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity.
Specification:-
- Diagonal: 27"
- Panel: AH-IPS LED-backlit
- Display area h x w 335.7 x 596.7 mm; 13.2" x 23.5"
- Response time: 5 ms
- Contrast: 1000:1 typical
- Contrast: 5000000:1 ACR
- Brightness: 350 cd/m² default, 440 cd/m² typical
- Viewing zone: horizontal/vertical: 178°/ 178°; right/left: 89°/ 89°; up/down: 89°/ 89°
- Display colour: 16.77 million
- Pixel pitch: h x v 0.233 x 0.233 mm
- Native resolution: 2560 x 1440 ( 3.7 megapixel)
- Horizontal sync 30 - 80 KHz
- Vertical sync 55 - 75 Hz
- Synchronization Separate Sync
- Colour range: AdobeRGB: 86%, sRGB: 116%, 82% (NTSC)
- Connections: VGA, DVI-D, HDMI & DisplayPort
- HDCP: Yes
- Dimensions: w x h x d 650 x 435.5 (564.5) x 230 mm
- Weight: 8.2 kg
- Warranty: 3yr
ORDER NOW
We've also performed test on select models, by changing the image to a corporate image to an image with a car or female on, the results in most cases were sales doubling.
Things need to be eye catching and our over 90% of the visitors to our website are male is hence the decision that our monitors feature stunning ladies, stunning cars or gaming titles or something very vibrant in colours.
If with time the traffic and age group to our website changes then of course we can add more hunks and corporate images but right now it is proven to increase our sales and OcUK is regarded as the UK's no.1 for high-end monitor sales, example Samsung 4k, OcUK has achieved no.1 sales in Europe, our image is a beautiful women which was approved by Samsung to use. :)
Shame tthere's no SSD's.
We only have one exclusive SSD brand which is Mach Xtreme and they have no deals at moment unfortunately.
The idea of this is to promote our exclusive brands/deals, the only deal which is not exclusive posted here is the G-Sync AOC and Samsung 4k but our prices are the best and we have stock. :)
