- 1 Mar 2004
- Warwickshire
Sitting at the lights with your foot on the brake when the light is low is really annoying for the driver behind, so I'd use the handbrake.
Leave it in D. In the new variants it disables the drive when you have the brakes applied. There were some issues with the earlier 6-speeds in hard stop-start use (if I recall correctly) but these have been resolved.
I still put mine into N if I sit for a while, it makes me feel better![]()
I pull up, put the electronic parking break on and about half the time put it into neutral, other half I leave it in drive. It disengages automatically when I go to pull away. But I have no idea what is best practice and what will give the box/clutch the easiest time.
Use it all the time, but it does impact rear pad life a lot!
I don't own one so may be wrong but i thought the advise was to not leave it in D holding on the brakes as the clutch will be at the biting point the entire time wanting to creep forward?
[TW]Fox;26759497 said:See, this is why you shouldn't have bought a previous decade Audi, your F10 would have auto applied the handbrake for you as soon as your car stopped![]()
No but I wouldn't worry about it unless you're a taxi driver in centre of a city. The friction materials are under almost no stress at tickover. Either way, you should be able to tell just from the way the forces affect the car if drive is being applied when you hold the brakes or not.Do you know when this was resolved? Mine has the 6 speed auto and I've always wondered if I should leave it in D or go into N.
Has been the case on the 5 for a long time, no? I put it down to rear brake bias under normal braking conditions, which reduces dive.[TW]Fox;26759539 said:I'm not sure it's Auto H that does that, it just seems to be an F10 'thing'. Rear pads last about half as long as front pads which is completely bizarre.
'Traditional' automatics use a torque converter. The converter is under virtually no stress by being in D while on the brakes. You could sit like that for 100 years and it wouldn't cause a problem.I thought autos use a torque converter, or does it vary? I can't image a fluid coupling undergoes the same stresses as a clutch plate.
Hmm I'll check then. It's an a4 black edition 2.0 177ps Quattro s tronic with technology pack high. Doesn't list that option, unless it's standard. I'll have a butchers, and I didn't even think to try it on the test drive.
Surely it is more akin to an automatic than a manual in that sense, unless it stalls? Both an automatic and manual creep if you are already moving, but only an auto creeps from a stop.The BMW is modelled to emulate a manual so off the brakes it will creep
We paid £200 for the auto hill hold assist and I just leave it in D when on the brakes. Press a little harder on the brake pedal and a green handbrake light automatically pops up. I.e. The handbrake (electronic) is engaged. As soon as you press on the accelerator it disengages and your on your way.
