Help with replacment fuel lines.
7 Dec 2002
UK
I need some assistance with the fuel lines for an engine I'm fitting as I need to replace the line from the fuel filter to the fuel rail & the return pipe back to the tank.
The problem is these are the old connectors & one of the old lines-
I have no idea where to obtain replaecments or even if those old fittings may be re-useable, obviously the last thing I want is an underbonnet fire so any help on this appreciated muchly!
They should be reusable, they're just brass. The 205 GTI has them, they're called barbed fittings, I think Pirtek can supply equivalents if you wanted brand new ones.
Thanks, what about the ribbed bit inside the hose? Or is that just thanks to the fitting being wedged in there since 1992?
