As title says ! thinking of going for this ? worth it ?
http://www.overclockers.co.uk/showproduct.php?prodid=BU-012-GI
Depends on what you use your computer for.
I went from a i7 950 @ 3.8 ghz (paired with a r9 290) to a 4790k with the 290 obviously.
The major difference in games I found was a bit better maximums but far better minimums. Overall the experience is a lot smoother.
I assume you play games? If so what graphics card do you have? You would probably see more benefit from upgrading your graphics card and overclocking your CPU to an inch of its life![]()
Still waiting for an answer.
No need to shout dude...
Depending on what you are using and encoding to, you might get better performance from upgrading your GPU to something with some mean CUDA skills.
How much money do you want / have to spend?
Yes, i went from a 920 to 4790K OC to 4.7 and the change is HUGE!
Thanks just what i wanted to hear![]()
. Enjoy 4790k is amazing, but i would have waited for x99 benchmarksYes, i went from a 920 to 4790K OC to 4.7 and the change is HUGE!
