Which brings me to a favourite question for all the druggies: how do you know you have ever taken a drug that you believe it to be? That tablet that you really liked, so you assumed it was MDMA, for example. How do you know it was? Please don't say "I tested it", because unless the test was done by a reputable laboratory with at least one EI mass spec and a good library I'm just going to laugh at your naiveté. And don't say that you saw the results of a test on an identical tablet, because that's nonsense as well.
I can say "it was tested" because it was. There are 5 reagent tests to test for MDMA and using all 5 will without a doubt tell you what is in your substance. Also there are harm reduction sites out there that report on pills including results from test centres (dotted around Europe, Holland Switzerland being the most prominent) that will tell you the amount of the chemical in your pill (excluding binder etc). They also report on multiple of the same pill and build up a database of the "spread".
You can laugh at my (our?) naiveté all you like but from a harm reduction point of view all of these things combined has done us as a community quite well for many many years. Just because you choose to sit on a high horse doesn't mean these things don't work and don't save lives.
Some of us "druggies" aren't your average idiot who will buy anything from the local corner man and don't really care what it is they are actually buying, as long as it gets them high. But, you know, don't let that get in the way of your crusade or anything.
