Help me identify connections in new house.
19 Jun 2009
I purchased a reprocessed home, and consequently there was no previous owner to ask anything.
The house has quite a number of wall plugs and also cables coming from the wall and i'm trying to determine what exactly is what. I can say there is 2 satellite dishes on the house, I have only noticed one TV aerial.
I've taken some photos if anyone could please help.
I presume the FM/DAB is for analogue / digital radio? The two below are these Satellite?
http://www.yourmenu.co.uk/other/plug0001.jpg
The following are split from a single cable? They come from a satellite dish.
http://www.yourmenu.co.uk/other/plug0002.jpg
I presume this is TV, but what is the other one, could it be another satellite cable?
http://www.yourmenu.co.uk/other/plug0003.jpg
This is a cable above the one photoed above? How come some satellite connections are in pairs, and some are single?
http://www.yourmenu.co.uk/other/plug0004.jpg
Another single satellite cable, this comes from the same dish that provided the two paired cables.
http://www.yourmenu.co.uk/other/plug0005.jpg
I have 2 dishes on the house, they both point at different angles. Can they be used for anything? Both are in a general east / south direction.
http://www.yourmenu.co.uk/other/plug0006.jpg
http://www.yourmenu.co.uk/other/plug0007.jpg
Thanks for any help.
FM/DAB, as you say; the RF socket (under the TV title) is likely to be from your roof/antic antenna; the second RF socket is either another feed from your antenna or a loopback (the RF output of a Sky Box) to a distribution amp to feed the rest of the property.
I presume this is TV, but what is the other one, could it be another satalite cable?
TV and single Sat feed.
Multiple Sat feeds allow you to use Sky+ or any other PVR Sat set-top-box with multiple tuners.
Likely they're both pointing at 28.2°E to one of the Astra sats, in which case you can use it for Sky or Freesat etc.
Thanks for above. Both dishes are definitely pointing at different angles.
Presuming these are both Astra, would one be the old Astra satellite from 20 years ago, and the other newer Freesat that I presume is digital?
The fact that you have two dishes on the house, and it looks like both have Quad LNBs, suggests that the house could well have had multiple satellite boxes. The only way to know for sure will be to disconnect and then buzz out all the connections with a multimeter. It's a PITA to do, but you'll save time in the long run.
Sky and Freesat are from the same satellite position - Astra 28.2°E. You wouldn't need dishes pointing in two different directions to pick up either or both services.
As for your plates and cables:
TV, FM/DAB and SAT1 signals all come down via one coax cable. There's a filter on the back of the socket that splits the signal originally combined by the TV distribution amp somewhere in the house. SAT2 is a direct coax feed. The TV socket next to the phone jack would normally be for the return signal from Sky's RF2 Out. This would go back to the distribution amp. Take the wall plate off. If you find three coax cables then my educated guess is correct.
Looks like poorly terminated Sky "thin twin" shotgun cable - WF65 or similar.
This looks like either a very basic diplex (frequency filtered) plate with a single coax feed (TV/SAT) or just a basic contract plate where there are two sables for direct feeds from the TV aerial and a satellite LNB.
Standard RG6/WF100 size satellite coax feed. Probably direct from one of the Quad LNBs.
As above
Lucid thanks for your help,
Yes i'm pretty sure the house had multiple satellite box's. There is a high amount of cables in the attic, the chap who owned the house worked in house electrics, bit of a gadget guy apparently, there is zone lighting in my house and underfloor electric heating.
http://www.yourmenu.co.uk/other/plug0002.jpg - Upstairs bedroom
http://www.yourmenu.co.uk/other/plug0005.jpg - Conservatory, this and above from same dish.
The above wires all come from this satellite below, you can see the two wires that are doubled up together.
Both my dishes are at different angles. I did a check on a site entering postcode, and they both appear correct for 28 degrees, however one satellite is definitely pointing lower to the sky.
This is the one pointing lower
So the connections that say FM/DAB, these are taking aerial from the regular TV aerial, but using a filter?
What is a Sky FN2 out?
Yes there is lots of TV cables in attic not connected, there is a board with mains plugs, however the TV amplifier is missing - reprocessed house so presume he took this with him before leaving.
Finally, i'm building a media center PC for front room, someone on here is selling a Quad TV tuner with Satellite input (see link below), is this compatible with things I have in the house.
http://www.techradar.com/reviews/audio-visual/digital-tv-recorders/black-gold-bgt3540-452320/review
This are the plugs where the media PC would go
http://www.yourmenu.co.uk/other/plug0004.jpg - the other plugs (in picture background) are 5.1 audio cable plugs for front room.
As you can tell i'm a novice when it comes to satellite equipment :rolleyes:
It's no big deal to get the dish(es) realigned.
How it works is the house has aerials for TV, and one FM radio and one for DAB; so three in total potentially.
The larger and more comprehensive aerial amplifier/splitters have inputs for the three types of aerials plus a satellite dish input. Because the frequencies don't overlap, it's possible to combine them (multiplexing) without mixing them up. The wall plate at the TV-end has frequency filters so that the signals are separated back out to their constituent parts.
The benefits are obvious: one wire instead of 4 to carry TV,FM, DAB and satellite to each room.
In reality, putting the satellite through a system like this is a PITA. Most of us have satellite receivers with dual tuners, and that means two sat cables immediately. Second, if there's multiple boxes in the house then only one sat box can be connected to the aerial distribution otherwise there's a risk of a signal conflict when two boxes call for different channels.
The practical solution for most people with Sky or a dual channel Freesat recorder is to ignore the distribution system completely and send the LNB signal directly to the receiver. That works for most folk with, and a Quad LNB will support two dual-tuner recording boxes (eg Sky HD) or one recorder and a couple of live view TVs/receivers. Once it gets beyond that then the bodge is to put up a second dish. The proper way to do it is with something called a 'multi-switch' running off a single dish.
It's RF2, not FN2. :D
If you have had a Sky box then you might have seen it has aerial connections on the back. This is a "pass through" feature where the Sky satellite receiver can add an analogue version of its output to the TV aerial signal. It's the same principle as used with VHS video recorders before SCART and AV connections became common. You'd tune a spare TV channel to the VCRs signal, then switch to TV channel 0 or 6 or whatever number you'd used when you wanted to watch recordings or films.
A Sky box works very much the same way. It's possible to add its signal to the aerial feed being distributed around the house. In this way it's possible to watch the same channel as being viewed in the lounge in other parts of the house. There are two aerial (RF) outputs on the back of a Sky box; RF1 and RF2. The second one allows a remote control signal via the TV aerial cable. This means watching Sky in a bedroom or the kitchen can work the same as the lounge: Ch +/-, pause, play, rewind, record etc. RF2 is the aerial socket on a Sky box for this control.
Sounds about right.
Sounds about right.
Yes.
DVB-S is standard definition digital satellite (FreeSat to you and me). DVB-T is standard definition terrestrial TV (Freeview to you and me). DVB-S2 and -T2 are the respective versions that include HD signals.
To make full use of the tuner cards features you need three connections: two direct feeds from the LNB for satellite (i.e. not doubled up from a single cable using a 2-way splitter because Satellite won't work properly like that), and one TV coax feed.
TBH, with such a jumble of wiring and multiple dish feeds and the need for an aerial amp I'd be tempted to call in an aerial guy to come sort you out. It's highly unlikely you need 6 or 8 satellite LNB feeds unless you have multiple Sky subscriptions of a lot of Freesat TVs and recorders. Get one dish taken down and the cable removed off the face of the house. Have the other dish aligned properly, and recabled if required to get feeds to your lounge if they aren't already there. Finally, have an aerial amp installed and the aerial changed to a Log Periodic. This will be the most future-proofed terrestrial aerial choice to cope with the channel changes still in progress as new HD channels come on stream.
