Hi guys,
When I play music in my car through an aux cable the quality is no way near as good as a normal cd! Is there anyway I can like make the music files better quality? Will they be better quality if i put them on a blank cd?
Thanks guys
	I know this is probably a stupid questionI just want to know if I can make the sound better quality through an aux?
Yes, as Acme said, better quality music files. Putting them on CD won't make a single bit of difference. That's like taking a turd then carefully gift wrapping it before inserting it into your enemy's letterbox. Same ****, different format.
You need to get music in FLAC or APE format. Then you will need a music player in your car that supports that format. Converting mp3 or m4a to flac will be pointless, you need to get in flac directly or rip an audio cd that you own to flac format.
I'd hazard a guess you're using something like youtube to mp3 converter which is really poor and will rip an already bad quality song to 128kb/s to even poorer quality.
People still use mp3 ??
With the abundance of storage space I'm surprised more people aren't using FLAC, I have not touched anything except lossless for years now!!
A 4:00m track in FLAC using the highest compression is approx 30MB
