Painting Copper Pipes
Have you considering using sleeving instead?
Search Plumb-Pak Radsnap Radiator White Pipe Sleeves. Much better finish than painting.
I done this for an install and had to paint the pipes red and blue for flow and return. What i done is clean, degrease, clean, degrease the pipes then primer and top coat, i used a red/blue emulsion and they come up really well.
