** ADATA XPG Z1 DDR4 NOW AVAILABLE!! **
OcUK Staff
17 Oct 2002
OcUK HQ
productAD33.jpg~original
Hi there
For those who want some truly unique looking RAM and the only company to have low-latency version, check out Adata:-
Adata XPG Z1 16GB (4x4GB) DDR4 PC4-17000C15 2133MHz Quad Channel Kit (AX4U2133W4G15-QRZ) @ £199.99 inc VAT
ADATA XPG Z1 DDR4 overclocking memory is designed as the ultimate upgrade for overclockers, enthusiasts, and gamers thanks to its remarkable performance and power efficiency. Even with speeds of up to 2800MHz and a transfer bandwidth reaching up to 22GB/s, XPG Z1 consumes 20% less power when compared to DDR3. Utilizing Thermal Conductive Technology and 10-layer PCB with 2oz of copper, XPG Z1 provides excellent cooling performance, as well as great stability whether you are on the battlefield gaming or trying to achieve higher benchmarks while overclocking.
DDR4 outperforms DDR3 with improved performance and lower power consumption. The operating voltage has decreased from 1.5V to 1.2V, which is a 20% reduction of power, and keeps the system at a low temperature for stable operation. It only requires 1.2V to achieve high clock frequency of 2800MHz for overclockers. Additionally, the SPD (Serial Presence Detect) of XPG Z1 allows direct application without changing settings in the BIOS, facilitating usage and system stability.
The jet wing-inspired design of XPG Z1 combines the carbon texture used for race cars, symbolizing the pursuit of extreme performance. It also features excellent cooling and stable data transfer due to Thermal Conductive Technology and 10-layer PCBs with 2oz of copper to effectively reduce electric resistance and consume less power, which greatly enhances the quality of signal transfer.
XPG Z1 DDR4 DRAM Module is made of high-quality chips selected through a strict filtering process. It also uses the top quality PCBs (Printed Circuit Board) that effectively extend the lifespan of memory modules.
Specification:-
- CPU Compatibility: Intel Haswell-E ( LGA 2011-3 )
- Chipset: Intel X99
- Capacity: 16GB (4GBx4)
- Quad Channel kit: Yes
- Tested Speed: DDR4-2133 MHz (PC4-17000)
- Tested Latency: 15-15-15-35
- Tested Voltage: 1.2V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 288-pin UDIMM
- SPD Speed: 2133 MHz
- SPD Voltage: 1.2V
- Features: Intel XMP 2.0(Extreme Memory Profile)Ready
- Warranty: Lifetime
Only £199.99 inc VAT.
ORDER NOW
Adata XPG Z1 32GB (4x8GB) DDR4 PC4-17000C15 2133MHz Quad Channel Kit (AX4U2133W8G15-QRZ) @ £399.95 inc VAT
Specification:-
- SPD Voltage: 1.2V
Only £399.95 inc VAT.
ORDER NOW
Adata XPG Z1 16GB (4x4GB) DDR4 PC4-17000C13 2133MHz Quad Channel Low Latency Kit (AX4U2133W4G13-QRZ) @ £229.99 inc VAT
Specification:-
- Tested Latency: 13-13-13-31
- SPD Voltage: 1.2V
Only £229.99 inc VAT.
ORDER NOW
Adata XPG Z1 32GB (4x8GB) DDR4 PC4-17000C13 2133MHz Quad Channel Low Latency Kit (AX4U2133W8G13-QRZ) @ £439.99 inc VAT
Specification:-
- Capacity: 32GB (8GBx4)
- SPD Voltage: 1.2V
Only £439.99 inc VAT.
ORDER NOW
Adata XPG Z1 16GB (4x4GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit (AX4U2400W4G16-QRZ) @ £239.99 inc VAT
Specification:-
- Tested Speed: DDR4-2400 MHz (PC4-19200)
- Tested Latency: 16-16-16-35
- SPD Voltage: 1.2V
Only £239.99 inc VAT.
ORDER NOW
Adata XPG Z1 32GB (4x8GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit (AX4U2400W8G16-QRZ) @ £469.99 inc VAT
Specification:-
- SPD Voltage: 1.2V
Only £469.99 inc VAT.
ORDER NOW
Adata XPG Z1 16GB (4x4GB) DDR4 PC4-22400C17 2800MHz Quad Channel Kit (AX4U2800W4G17-QRZ) @ £349.99 inc VAT
Specification:-
- Tested Speed: DDR4-2800 MHz (PC4-22400)
- Tested Latency: 17-17-17-39
- SPD Voltage: 1.2V
Only £349.99 inc VAT.
ORDER NOW
Adata XPG Z1 32GB (4x8GB) DDR4 PC4-22400C17 2800MHz Quad Channel Kit (AX4U2800W8G17-QRZ) @ £666.66 inc VAT
Specification:-
- SPD Voltage: 1.2V
Only £666.66 inc VAT.
ORDER NOW
Yet another UK first and potentially another WORLD WIDE first for OcUK, AGAIN! :D
Nice to see ADATA making their way back onto OcUK with high-speed memory, but I think the last lot of XPG looked way better, the new inverted design just looks odd to me :(
Its about USP's and well its a different design. :D
Hmm.
I think it is quite ugly, actually.
G.Skill looks best so far.
And Avexir (we will remove the heatsinks anyway and slap the blocks on top).
