- 7 Mar 2013
- North East
I am having one of those moments .... I want to have a go at folding and did download FAH V2 but after that i got stuck
welcome to the fold.... i have slept since i used fah v2 but i find this it my help http://fahtracker.com/setup.html
that 7970 will punch some ppd out
dave
So I am up and running ... I can see project and points on the SMP but not on my gpu's it just says unknown is that correct ??
it should show something after it sorts it self out , you should just download the folding program, its not really hard to work either.
http://forums.overclockers.co.uk/showpost.php?p=24788107&postcount=56
right I have sorted it out and have joined the OCUK team ....
how do I know I am doing the max with my setup ??
The Extremeoverclock stats do have a time lag from your own upload as they only update every 3 hours or so, after folding themselves update.
Note your maximum output in folding won't show until you have done at least 10 units successfully so you can gain the quick return bonus.
seems your doing well.
