no internet
i reuploaded win 8 and then got a message ``no internet, check your router and broadband``.
i rang up talktalk and they said that files/folder that connect me to the router are missing, i've never set up broadband before on my pc, it was just plug and play.
are the missing files this:-
http://windows.microsoft.com/en-gb/windows/fix-network-adapter-problems#1TC=windows-8
thanks
I think they are most likely telling you you need to install your ethernet drivers.
What motherboard are you using?
