bigger majority of us using 1 gpu anyway , or you can use dual gpu eg 295x2 or future dual gpu card.
You can still use 2 gpu's with 0 difference at all with 28 lanes.
No you can not you need at least 32 lanes to run X16/X16
I would expect the above configuration to be the absolute minimum for any CPU with the label EE or HEDT.
I think it is disgusting as the old i7 920 has more PCI-E lanes.
I know they are PCI-E 2.0 but it is a joke if the 5820K can not even match the configuration.
The i7 920 had no PCI express lanes or controller only the X58 chipset hand them , it wasn't until Lynnfield that intel CPU's started having PCIE lanes/controllers directly built into them
The difference between X8,X8 and X16,x16 is so minimal. Tri SLI for example running at x8,x8,x8 would also be absolutely fine on the 28 lanes.
You are missing the point too
If I buy a HEDT CPU I want performance that is better than older CPUs not worse.
The point is if I put a couple of cards into one of my X58 systems they will run @X16/X16.
The CPU performance is better.
The 5820 isn't meant to be replacing the 4930, it's replacing the 4820.
If you go 4930 to 5930 you're not getting worse performance.
It is a poor move by Intel, but it's to be expected, they've just improved their price/performance CPU end at Hexcores, they've compensated with the PCI-E Lanes.
It's an entry level cpu. To get the sort of performance you want, then are you really going to buy a 5820k ? There is absolutely nothing wrong with running pcie 3.0 x16 with 1 gpu, x16x8 with 2 or x8x8x8 with 3. You're not going to get x16,x16,x16 out of a 40 lane anyway, and at x16x16x8 you'll prob start to get latency issues and I bet x8x8x8 wouldnt be too far behind at all.
That's a disappointment, looks like people will have to pay full whack if they want to use more than two gpu's then. Probably just a way for them to make more money and commence milking.
It's the low end of the new Haswell-E processors right?
At PCIe 2.0.....there is not even a native PCIe 3.0 interface on X58............
PCIe 3.0 per lane throughput might not be double that of PCIe 2.0 but it certainly caters for more than enough bandwidth for current GPUs.
there shouldnt be anything "only" about Haswell - E , which is a premium option already.
Make the cache the differentiator, not something crucial like PCIE lanes
After all this whole processor line is only appealing to a tiny percentage of users in the first place - high performance /extreme users - its a bit of a con to do this kind of thing imo
If I was going to get an Haswell-E in the near future I would be looking at the 5930.
The 5820 I am not keen on for the reasons above.
The 5960X concerns me a great deal as it has a very low stock speed and I suspect very poor overclocking performance (I hope I am wrong) as I can not see what is effectively two 4770ks strapped together doing very well.
That leaves the 5930 hexcore.
16x/16x/8x and 16x/8x/4x at PCI-E 3.0 should still be fine for tri-fire/SLI no? I can't see any cards exceeding PCI-E 3.0 8x bandwidth any time soon /shrug.
After all it is the equivelent of PCI-E 2.0 32x/32x/16x and 32x/16x/8x.
