Monsoon Fittings
6 Jan 2013
Rollergirl
My build is complete using Monsoon fittings. I'm looking to put a second GPU under water and need 4 of these bad boys...
http://www.overclockers.co.uk/showproduct.php?prodid=WC-117-MO&groupid=962&catid=2531&subcat=2537
Unfortunately, OCUK have been out of stock on them for weeks. I have checked elsewhere (I know, sorry OCUK) but they are either out of stock or £20 a pop.
Could any of you suggest an alternative fitting that won't look out of place with the current Monsoon fittings (see photos in my sig)? Is there a supplier you use that maybe I haven't tried?
I know OCUK frown on links to alternative suppliers, but this product isn't available from OCUK so maybe a mod could clarify if it's OK for folks to suggest a supplier that does?
Thanks in advance...
I think a lot of monsoon fittings are ordered in as an when required, out of stock for weeks probably mean they not had orders for them so if you order what you need you might have them by next week
I posted in the pre-sales section and they didn't mention that. To be honest, if I ordered right now and they took a fortnight to arrive I'd be happy enough with that.
Could a Mod confirm this is how it works?
Thanks for your reply, BTW stuie.
It might not be 100% accurate but im sure I recall a post by someone saying they are made to order but it might have just be a short term thing while stocks were low
Ask in the customer service thread when they will be back in stock and if they can be ordered just for you.
What cards and what blocks will you be using, it is possible that they will still match up.
As previous post, I think I'll look at switching to alternative fittings as the Monsoons aren't easy to source.
I recommend the EK nickel ones, used them in a recent build and they're very nice and amongst the cheaper fittings.
I used all monsoon fittings 16/10 in gold and had to scource from 4 different suppliers to get all the angle fittings I needed. No one stocks large quantity.
