** FREE 8GB 2400MHz MEMORY KIT & AMD GOLD VOUCHER WITH POWERCOLOR 290/290X PCS+ CARDS!! **
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
A truly insane offer, when you buy a Powercolor 290/290X PCS+ you will get for FREE:-
AMD Gamer 8GB (2x4GB) PC3-19200C11 2400MHz Dual Channel Memory Kit (R938G2401U1K) @ £89.99 inc VAT
AMD Memory is designed to deliver memory that is optimized and certified for AMD Platforms and components and also delivers quality and reliability to compatible chipsets and processors from other manufacturers. High-quality DRAM parts (no ETT) help ensure no dropouts and no data loss. With AMD memory you get the performance you need for all your applications.
Features:
- Black PCB
- Black high performance heatspreaders
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- CAS Timings: 11-12-12-31
- Dual Channel Kit: (2x4GB)
- 100% tested at 2400MHz in AMD 990FX & Kaveri APU based motherboards
- Lifetime Warranty
Only £89.99 inc VAT.
ORDER NOW
AMD Radeon GOLD Reward Ticket (Emailed) @ £89.99 inc VAT
Choose 3 FREE Games from AMD between now and end of this year with this GOLD Reward for purchasing an R9 295/290/280 series graphics card.
1. www.AMD.com/radeonrewards
2. Sign in or create an account
3. Follow the instructions to redeem your offer with the code on the ticket
4. This voucher will automatically attached to your order when ordering a qualifying car
5. Ensure you put a valid email address when placing your order as your Golden Ticket will be emailed her or you can retrieve by logging into your account at OcUK.
ORDER NOW
The qualifying cards are:-
Powercolor Radeon R9 290X PCS+ OC 4096MB GDDR5 PCI-Express Graphics Card with FREE AMD 8GB 2400MHz Memory Kit @ £389.99 inc VAT
PCS+ Version features Powercolor's amazing tri-fan cooler, for much lower noise levels whilst offering superior cooling. Along with a great overclock out the box, this card runs at 1050MHz core and 5400MHz memory.
AMD Radeon R9 290X is a new graphics card powered by the latest AMD Radeon™ R9 290X graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:-
- Radeon R9 290X
- GPU: Hawaii XT
- Litecoin Hash Rate: 850-1000
- Stream Processors: 2816
- ROPS: 64
- Core Speed: 1050MHz
- Memory Speed: 5400Mhz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- Cooling: 2-Slot Blower Fan
- Fan Speed: 20% - 40% (Quiet Mode) & 20%-55% (Uber Mode)
- PCI-Express X16 lane required
- 750W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Comes with BF4 Voucher included in the box
- Warranty: 2yr
Only £389.99 inc VAT.
ORDER NOW
Powercolor Radeon R9 290 PCS+ OC 4096MB GDDR5 PCI-Express Graphics Card with FREE AMD 8GB 2400MHz Memory Kit @ £305.99 inc VAT
PCS+ Version features Powercolor's amazing tri-fan cooler, for much lower noise levels whilst offering superior cooling. Along with a great overclock out the box, this card runs at 1040MHz core and 5400MHz memory.
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:
- Radeon R9 290
- GPU: Hawaii Pro
- Litecoin Hash Rate: 800-950
- Stream Processors: 2560
- Core Speed: 1040MHz
- Warranty: 2yr
Only £305.99 inc VAT.
ORDER NOW
Also in case anyone was wondering the AMD memory works fine in Intel chipset mainboards at 2400MHz as well. :)
The value of these items means your getting a 290X for less than £300 and a 290 for less than £200.
This bundle promotion is EXCLUSIVE TO OVERCLOCKERS UK!! :D
Hi there
A couple more great deals from Powercolor:-
Powercolor Radeon R9 280X TurboDUO 3072MB GDDR5 PCI-Express Graphics Card @ £199.99 inc VAT
Powercolor R9 280X has the performance to power the latest games with ease but at a very aggressive price point making it incredible value for money.
Equipped with TurboDUO near silent cooling solution meaning you can game in near silence whilst keeping the card nice and cool.
Features:-
- Multi Phase Design: 8 Power Phases for improved OC ability
- Digital PWM
- Ferrite Core Choke: Decreases ripple to deliver more stable voltage
- DirectFET
- Patent GSG- Shape Heat Pipes Design: Reduces temperatures by upto 17% and noise reduction of upto 19%
- Pure Copper Base
- Backplate included
Specification:-
- Litecoin Hash Rate: 550-750
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Hugely overclockable
- Core Clock Speed: 880MHz
- Boost Clock Speed: 1030MHz
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 6000MHz
- Display Outputs: 1x DVI + 1x DP + 1x HDMI
- Power: 250W TDP
- 2yr Warranty
Was [£215.99] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
Powercolor Radeon R9 280 TurboDUO 3072MB GDDR5 PCI-Express Graphics Card @ £149.99 inc VAT
Features:-
- Digital PWM
- DirectFET
- Pure Copper Base
Specification:-
- Core Clock Speed: 855MHz
- Boost Clock Speed: 960MHz
- Stream Processors: 1792 ALU
- Memory Width / Speed: 384 bit / 5000MHz
- Power: 250W TDP
- 2yr Warranty
Was [£155.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Powercolor Radeon R9 270 TurboDUO 2048MB GDDR5 PCI-Express Graphics Card @ £99.95 inc VAT
The AMD Radeon R9 270 GPU continues AMD’s tradition of delivering world-class performance, features and multi-monitor support at an incredible value,” said Matt Skynner, corporate vice president and general manager, Graphics Business Unit, AMD. “With Mantle, exceptional performance and ultimate gaming experiences are synonymous with AMD Radeon R7 and R9 Series graphics cards. Once again, AMD proves that Radeon™ is gaming.”
Specification:-
- Litecoin Hash Rate: 350-500
- Core Clock Speed: 930MHz
- Core Boost Speed: 955MHz
- Stream Processors: 1280
- Frame Buffer / Memory: 2GB GDDR5
- Memory Width / Speed: 256 bit / 5600MHz
- Power Connectors: 6-pin + 6-pin
- Power: 180W TDP
- 2yr Warranty
Was [£125.99] Inc. VAT
Only £99.95 inc VAT.
ORDER NOW
They are great cards at a great price point! :)
This is depressing to see, I only just purchased a 290(xfx) on monday from you guys and now this offer comes out :( :( :( I would have gladly bought this one for the freebies since im watercooling it anyway
Amazing deal there for anyone in the market for a 290! or in fairness just doing a new build
Props to OCuk as always :D
How long is this deal good for? will be buying a lot of gear next Friday and a would rather way to get everything shipped at the same time then.
Can someone help me here - I'm finding it hard to see a list of the games offered, the ones I can see don't look particularly great. Being able to sell the RAM on ebay easily for £75 is a big bonus tho....
Not sure if there is an error on the site, but the price for the power colour 290x has gone up from £359:99 to £419.99.
I was waiting until Friday to place everything in a single order, like I asked above.
Not an error as the RAM has run out, so were just trying to stop customers buying.
RAM will be back in next week and which point the FREE RAM will be back as will the lower prices. :)
P.S. Or if you prefer I can do the price slightly lower than it was but with no FREE memory kit, let us know.
