Illuminate your bedroom or any LAN event with these Ultra Bright and Intense Colours.
BitFenix Prodigy M MATX Cube Case - Red @ £69.98 inc VAT
Reimagined with micro ATX compatibility, Prodigy M enables users to install multiple expansion cards while maintaining the same compact dimensions and sleek look of the original Prodigy. Suspended with two FyberFlex Composite handles for shock absorption, Prodigy M can be easily transported to the next room or to the next LAN party.
The inside is incredibly flexible, offering space for SLI or Crossfire dual graphics technology, up to four 3.5" hard drives or five 2.5" SSDs, and even space for slim 240mm radiators. A magnetic heat shield is also included should you decide to fill the bottom with hard drives rather than fans. With BitFenix SofTouch Surface Treatment, a massive CPU cooler cutout, and rolled-edge cable pass-throughs, the small case that does it all returns with a vengeance.
Full MATX Compatibility
You asked, we delivered. Prodigy M now features full compatibility with micro-ATX motherboards, all while maintaining the same compact dimensions as the original award-winning Prodigy. Featuring an all-new layout, Prodigy M is truly flexibility reimagined.
Sleek and Compact
One thing that hasn't changed is the sleek and clean look of the original Prodigy. Sporting two exquisitely crafted handles that suspend the body, Prodigy M has the same modern yet elegant styling that made the original the small form factor case of choice for PC enthusiasts the world over.
Tremendous Flexibility
Of course, Prodigy M couldn't carry the Prodigy name without the flexibility to match. Aside from both micro ATX and mini-ITX compatibility, Prodigy M can be configured with up to four 3.5" HDDs or five 2.5" SSDs for excellent storage potential. Adding in a micro ATX motherboard gives you up to four expansion slots, perfect for additional expansion cards, or even SLI and Crossfire dual graphics capability.
Multiple Cooling Options
To keep things running frosty, Prodigy M can be outfitted with up to five fans for maximum cooling. Bolt a thin 240mm radiator on top, or perhaps a 120mm radiator on the rear. With the roomy interior, even tower CPU coolers up to 160mm will fit with ease. No matter how you prefer to cool your system, Prodigy M has you covered.
- Materials: Steel, Plastic
- Colors (Int/Ext): Red/Black
- Dimensions (WxHxD): 250 x 404 x 359mm
- Motherboard Sizes: Micro ATX, Mini-ITX
- 5.25” Drive Bays: x 1 (removable)
- 3.5” Drive Bays: x 4 (2 + 2)
- 2.5” Drive Bays: x 5 (3 + 2)
- Cooling Top: 120mm x 2 (optional)
- Cooling Bottom: 120mm x 2 (1 included) or 200mm x 1(optional) or 230mm x 1 (optional)
- Cooling Rear: 120mm x 1 (included) or 140mm x 1 (optional)
- PCI Slots: x 5
- I/O: USB 3.0 x 2, HD Audio
- Power Supply: PS2 ATX (bottom, multi direction)
- Extras: FyberFlex™ Composite handles, SofTouch™ surface treatment, heat shield
Only £69.98 inc VAT.
ORDER NOW
BitFenix Prodigy M MATX Cube Case - Orange @ £69.98 inc VAT
Sleek and Compact
- Colors (Int/Ext): Orange/Black
- PCI Slots: x 5
ORDER NOW
BitFenix Prodigy M MATX Cube Case - Blue @ £69.98 inc VAT
Sleek and Compact
- Colors (Int/Ext): Blue/Black
- PCI Slots: x 5
ORDER NOW
BitFenix Prodigy M MATX Cube Case - Green @ £69.98 inc VAT
Sleek and Compact
- Colors (Int/Ext): Green/Black
- PCI Slots: x 5
ORDER NOW
also availible specially designed window side panels in the colour to match y our case.
BitFenix Prodigy M Windowed Side Panel - Blue @ £9.95 inc VAT
You can now customise your unique prodigy case even more now with the windowed side panel.
- Windowed side panel
- Material: Steel
- Colour: Blue
- Compatibility: BitFenix Prodigy Micro-ATX case
Only £9.95 inc VAT.
ORDER NOW
