The 5930k is poised to cost quite a chunk more than the 4930k does now.
I seem to recall some one saying around £480.
Native Gen 3 for AMD, you need to use a hack to enable for Nvidia (690's apart)
http://www.techpowerup.com/168027/n...g-patch-for-sandy-bridge-e-hedt-platform.html
Wrong, the USD cost between 4930k and 5930k is no different.
GBP price will be higher as pound has being weakening all week, but Intel are not to blame for exchange rates.
Just an update Scotty.. Didn't work mate. Apparently only works on the 6x0 original Titan and 780. Doesn't work on 780ti or TB you need Ivy for those![]()
Well then hey, at least that's good news.
Still a shame to see that there's always an excuse to over charge in the UK though. Nice to see the customer always has to foot the bill for things like exchange rates and so on.
They charge you at current price not stock price = more profit it is a profit making company after all.
The Sandy Bridge-E was not officially PCI-E 3.0 because the ports signalling to the graphicscard was over a certain margain, that was accepted for PCI-E 3.0 standard. AMD didn't see it as a problem an never adresse the issue within their driver to lock the cards to PCI-E 2.0.
NVidia on the other hand saw it as a potential issue and didn't want to be pointed at for possible signalling issues, so they per driver level limited all GTX 600 series to PCI-E 2.0. On the users own precaution they release the nVidia X79 PCI-E 3.0 Patch to be able to run PCI-E with GTX 600 series cards on a Sandy Bridge-E CPU.
The GTX 690 is per default running PCI-E 3.0 since all signalling and communications is done internally between the two GPU's leaving the CPU out of the equation, and hence no potential issues regarding the CPU.
With that said one question bugs me.
Can you run 3-way SLi with a 5820K ?
If I remember correct nVidia doesn't allow or support running SLi at anything lower than PCI-e x8 pr lane !... or am I wrong ?
It does work ! You have to run the patch as Administrator and then reboot your PC.
I had a Core i7 3930K with 3x 780's and a Core i7 3820 with 2x 780Ti's and both systems ran PCI-E 3.0 after the patch had been applied. Only down side was that you had to repeat this procedure every time you update your GFX drives.
Now with 4930K's in both systems I don't need the patch and they run PCI-E 3.0 natively.
I'm I being dumb here ? Ok they charge you at current price but surely the price you have paid is the price you have paid. If its in your warehouse the price isnt going to go up just becuase the exchange rate has changed ?
I still don't understand it.
Company calls distributor to get product, product bought for say £1000. It arrives at companies warehouse. Product then put on sale to the public.
Why would fluctuating conversion rates affect the cost to the public when the price was already set at £1000. I understand that if you bought more product, then it would/may be different but if you already have stock why would the price differ ?
They have to restock, so they charge you what it would cost to rebuy stock![]()
Will this have any impact on 2 x High end GPU's and 4K?
I don't plan on ever going more than a 2 card SLI setup, so if not and the price is right no complaint from me.
