For the princely sum of 100 pounds...
30 Aug 2007
What GPU should I get for (sort of) around £100?
My spec is as signature + an 850W PS.
Will there be any issue using newer cards with my old UD5 MB?
I'm wanting to go nvidia this time for a couple reasons: ShadowPlay and CUDA support (for accelerating rendering)
I've been looking at the MSI 750 Ti, seems to review well, but are there other options?
Thanks as always for the help! :)
The 750ti is about the best you'll get from nvidia at that price point by the looks of it, totally overspecced PSU however as I recall its max draw is only 60w!
Any chance you could spend a bit more? A little extra can go a long way with the low budget stuff! Also new cards will be fine in that board (You'll just be running with Pcie 2.0 vs 3.0 that you get with the newer stuff. Negligible performance wise if you're running 8x and up)
Haha, yeah, thought that when I got the PSU ;) I'll probably build my next machine with it too :)
Ironically, that MSI 750 Ti doesn't seem to need a 6pin PCIe power either? Could upgrade my hardware and see the power draw of the machine actually fall :eek:
How much is "a bit more"? :D
I'm wanting something that'll run quiet when it's idling if possible...
Thanks for the help guys :)
Alternatively you could experiment with getting 2 GTX 480s... I have no idea if the software you use CUDA with would actually utilise both cards fully but if it did it it'd mean significantly more CUDA cores at work than a 750TI... 600w just on graphics cards though!
Tbh I explained that badly :)
It'll be mainly a games machine, but if I'm getting a new card then I'd want ShadowPlay and CUDA support (which seems to mean >=600 series (for ShadowPlay) iirc).
So it's a general machine: graphics, games, etc. :)
I'd consider an EVGA 750ti sc (not ftw heard it's noisy) or an AMD 265 which is a 7850, I've had loads of those since they came out and it's a decent card but if you really want Nvidia I've seen the 2gb GTX 660 for around 100 quid as well, That's not a bad card.
You can find 760's for around 150 if you can stretch to that, then your also in 270x territory
GTX 660 > 750 Ti? Know any good comparisons?
Saw one review of the MSI 750 Ti that seemed pretty favourable - http://www.overclock3d.net/reviews/gpu_displays/msi_gtx750ti_gaming_review/19
Not sure if that's up to date though :)
If you can find a cheap 660 it will do you really well. I had one for ages and I would still recommend it for 1080p. (still got it as I haven't gotten around to selling it yet)
MSI Twin Frozr version will be silent.
FYI AMD has a version of shadowplay called DVR that works in a similar way.
670's/680's are going for an extra £50 ish on your budget 2nd hand. A much better choice all around, Don't be afraid to buy 2nd hand as long as its from a reputable source. They come with far greater performance than the 750ti.
He doesn't have MM access and eBay really is a crap-shoot.
But yeah, in principle 2nd hand is a lot better value for money. My last two cards have been 2nd hand, and no worries with any of them. Both from here tho ;)
Yeah, think I'm sticking with nvidia: shadowplay & cuda support are attractive features.
You can record on AMD GPUs too, and if your rendering software of choice supports OpenCL you'll find equivalent priced AMD GPUs are about twice as quick.
For example, compare the 660 to the 270 in Sony Vegas:
http://www.anandtech.com/show/7503/the-amd-radeon-r9-270x-270-review-feat-asus-his/15
And it's £100 ;)
YOUR BASKET
1 x Powercolor Radeon R9 270 TurboDUO 2048MB GDDR5 PCI-Express Graphics Card £99.95
Total : £99.95 (includes shipping : ).
So something like a 670 would be preferable over a 760?
I've only been reading into gpus for the past few days after a few years off :)
Would there be any benefits over going for a 700-series card?
For example, compare the 660 to the 270 in Soy Vegas:
And it's £100 ;)
YOUR BASKET
Unfortunately it doesn't support OpenCL, but that performance (and thread-title-relating price! ;)) is really attractive...
Some of that comparison article is REALLY surprising to me.
The AMD cards seem to utterly outclass the nvidia cards in a number of the tests - the Lux Mark especially. But then the Sony Vegas test shows a GTX 760 only 2s faster than my very old 5770?
Is that sort of result indicative of gaming or other real world gpu-based tasks?
The plot thickens...
