48 hour Titan Fall test unplayable, constant HDD accessing
Caporegime
17 Mar 2012
ARC-L1, Stanton System
I just DL'd the 48 play for free to test the game out before buying it, however, i can't play it, serious problem with it.
The game will launch by stutter along at 1 FPS with extreme input lag, i figured out why.
Drive C is running at full when the game is running, see pic.
Its not even instilled on C as its an SDD with limited capacity, i have the game installed on a mechanical drive, like many others.
I have checked the game files in Origin ecte... all seems ok and yet it will run like this...
Please help, 48 hours access, if i don't get this fixed soon it will expire before i get to test it.
Thanks
FX-8350 @ 4.6Ghz
Powercolor PCS+ R9 290 @ 1100/1407
4x 2GB RAM
http://i1056.photobucket.com/albums/t364/Hunbug76/TF_zpsbfe9fb36.png
What's the capacity of C: before you launch? If it's creating some big temp file you might be able to find it with SpaceSniffer and from there google what it is.
Its a 120GB Samy 830 with 20GB free space.
I got it working, i closed MSI AB and Gaming Evolved, i restarted Gaming Evolved and its still working, have not tried it again with MSI AB yet.
It did exactly the same for me when it was last on game time but I didn't manage to sort it.
The furthest I got was the loading screen and like you say it just sits at 1fps.
I don't think I turn AB off though so you may have sussed it.
Won't let me run game time again so I can't test it.
Do you think it could be page file on the ssd being a problem?
Don't know, i thought it might be, had mine set to 2Gb, set it to 6GB and it was still kaput, its only when i closed MSI AB and Gaming Evolved that fixed it, i have since restarted Gaming Evolved and its fine.
After starting MSI AB it all went to poo again, closed it and its fine.
Its defiantly MSI AB (4.0.0 Beta 9)
I downloaded the game time trial and it loads fine but when I connect to a server it just stays on the loading screen forever...
I assume it would be the same with the full game because isn't the game time version simply the full game with a time limit? I don't have afterburner installed and its never been installed.
