- 22 Apr 2014
Devolo are Launching a new faster range of Powerline adapters to carry on from there 200Mbps, 500Mbps and 650Mbps ranges of Powerline. These new 1200Mbps powerline adapters offer gigabit network speeds. Quickly and easily network your house with these new adapters and you don't even loose any plug sockets due to the AC pass through.
You will have to wait a couple of weeks before we get the stock in but they are available for pre-order now. I hopefully will be getting a sample shortly so I can put them through there paces and see how good they are.
Devolo dLAN Powerline 1200 Plus (Gigabit Ethernet) Single Pack (9371) @ £64.99 inc VAT
The latest Powerline generation – devolo dLAN® 1200+. You can easily build today‘s most powerful home network over the power line: connect your network-compatible devices at speeds up to 1,200 Mbps for advanced data transmission and lightning-fast Internet access. Connecting your computer, TV or game console to the Internet via adapter with Gigabit LAN port is a breeze. The integrated range+technology ensures a stable connection with significantly longer range than before. Rely on the new dLAN® generation from devolo – the global Powerline market leader.
Highlights:
Only £64.99 inc VAT.
ORDER NOW
Devolo dLAN Powerline 1200 Plus (Gigabit Ethernet) Starter Twin Pack (9378) @ £119.99 inc VAT
Highlights:
Only £119.99 inc VAT.
ORDER NOW
Highlights:
- Your home network from the power socket. Unpack. Plug it in. Get started. The easy way to connect using your home‘s power lines. Turn any power socket you want into an Internet access point.
- The optimal Internet connection for computers, televisions and game consoles. No signal loss – stable and continuous.
- Lightning-fast 1,200 Mbps speeds for the most demanding data transmission.
- Even higher performance and longer range with range+ Technology.
- Installation is a breeze. Just unpack it, plug it in and get started.
- With the Gigabit LAN connection you can connect an Internet-compatible device at any time via network cable to the Internet (e.g. game console or Smart TV).
- With the integrated electrical socket, no power outlet in your room goes to waste.
- Automatic encryption! Active protection against unauthorised access.
- Minimal energy consumption with the innovative PowerSave technology from devolo: Continuous, intelligent and fully automatic.
- Automatic phase shift: Makes Internet access possible in any room and sets up your home network in no time.
- Easily expand your network at any time and integrate additional devices into your home network with additional dLAN® adapters.
- Includes dLAN® Cockpit software for home network configuration on a computer (Windows, Mac OS® X, Linux®).
- Compatible with all adapters of the 200/500/650/1200 product series.
- Rely on number 1: More than 10 million satisfied devolo dLAN® customers around the world.
- Complete 3-year warranty.
ORDER NOW
Highlights:
ORDER NOW
