Black case for a business PC
13 Feb 2006
Can any of you good folks recommend me a good PC case for a business PC?
It needs to be black and have front USB 3 ports and not too big.
Price-wise, probably £50, £60 something like that.
Cheers :)
For the price looks like a good buy though maybe a little big for you ? : http://www.overclockers.co.uk/showproduct.php?prodid=CA-047-BX&tool=3 OR http://www.overclockers.co.uk/showproduct.php?prodid=CA-019-BX&groupid=2362&catid=2277
Here's one slightly more compact , though dearer : http://www.overclockers.co.uk/showproduct.php?prodid=CA-084-BX&groupid=2362&catid=2277
Would you consider a matx setup ? Can get some nice compact cases.
I like the look of all those cases but they look a bit flash for the office it's going in. It's just a sort of bog-standard but yet well-built case I'm after.
The Antec 300 looks good but it doesn't have the front USB 3, I was asked specifically to get one that has front USB 3.
The Corsair Carbide looks good but I'm not sure the top grill would be suitable. If the case was for myself I'd probably go for that one as it looks decent.
Just having a look at some more pictures of the Corsair Carbide and I think that might be alright, like I say the only thing that might be an issue is the top grill.
If I don't see any others then I think I might go for that one. If it's not suitable I'll just use it myself.
Thanks for all the suggestions so far, much appreciated. :)
All these are MATX I think you should consider them as ATX will just look too big for an office.
Sharkoon CA-M Micro-ATX - Plain case 2 USB
Fractal Design Define Mini micro - 3 USB but £10 over budget
Cooler Master Silencio 352 - Fits the bill
http://www.overclockers.co.uk/showproduct.php?prodid=CA-258-CM&groupid=2362&catid=2277
Lian Li - Plain but old
http://www.overclockers.co.uk/showproduct.php?prodid=CA-266-LL&groupid=2362&catid=2277
Cooler Master Silencio 452 - Looks fine
http://www.overclockers.co.uk/showproduct.php?prodid=CA-225-CM&groupid=2362&catid=2277
Context would have been nice. Who's office? Why does it need specific features? Why isn't it just hidden away like other office PCs? What hardware is going in it?
So why not some cheapo no-brand box?
I think I gave adequate info for people to make sound recommendations and I was happy with the recommendations made, I would have got one of the recommendations had I not seen the case I got yesterday.
Edit: Just editing this to add that the person the case was for is very pleased with it.
Thanks again for all the suggestions.
