I have (well, had) my 4690k overclocked to 4.2ghz that is stable with a voltage of 1.2 (in CPU-Z, 1.3v in BIOS - for some reason 1.2V is the lowest) and all was well til recently I noticed the max clock speed showing up is only 3500mhz, no more even under 100% load.
I have no idea why this is happening, i've redone my OC settings, reset the BIOS default settings and reconfigured, checked every setting to see what might be causing it but to no avail.
The only thing that lets it run at my set overclock is disablinlg Speedstep, but i've always had this on and it functioned perfectly with it on before? I don't want to force that off as i've always used Speed step with my older CPU's for the power saving.
Using an ASRock Z97 Extreme4 motherboard, i'm just completely stumped.
What could be the problem? i've checked windows advanced power settings and everything is set as it was.
Any help much appreciated
that's why I'm so confused, had no issues with it on my old i7-950 and on this for like, the first two weeks or so - only recent 'things' i've done is chipset drivers and update the BIOS to 1.30. Resetting the BIOS by removing CMOS battery wouldn't be any different to flashing it, right? Also set the power options to balanced, with the min/max processor states being at 5/100%.
