** BANK HOLIDAY TODAY ONLY: LETS GO CRAZY! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Very limited stock on this crazy offer guys:-
Asus VG248QE 24" Widescreen 144Hz 1ms Gaming LED Monitor - Black @ £209.99 inc VAT
Latest Asus VG248QE is a state of the art 24" gaming monitor with industry leading features such as 144Hz refresh rate for super fluidity in the latest games. 3D Vision 2.0 support, so bring your games to life with NVIDIA 3D Vision (Emitter & Glasses NOT included). Plus the latest GamePlus technology, an Asus-exclusive GamePlus hotkey with Aimpoint and Timer functions in FPS and RTS games. To ensure games are ghost free the Asus also sports one of the industries fastest response times with just 1ms.
Features:-
- Gameplus: ASUS-exclusive GamePlus hotkey with Aimpoint & Timer functions in FPS and RTS games
- Ultra smooth action with 144Hz rapid refresh rate and 1ms (GTG) tracer-free
- Vivid color performance with Splendid™ Video Intelligence Technology
- A comfortable viewing with ergonomic design for swivel, tilt angle, and height adjustment
- Extensive connectivity with HDMI 1.4, dual-link DVI-D, and DisplayPort
- VG248QE supports NVIDIA 3D Vision 2 through connection of Dual-link DVI.
- Suggest purchasing the additional NVIDIA 3D Vision 2 Kit for immersive 3D enjoyment, also available from OcUK!
Specification:-
- Panel Size: Wide Screen 24.0" 16:9
- True Resolution: 1920x1080
- Full HD 1080P: Yes
- Brightness(Max): 350 cd/m
- ASUS Smart Contrast Ratio (ASCR): 800000000:1
- Viewing Angle (CR?10): 170°(H)/160°(V)
- Response Time: 1ms (Gray to Gray)
- Display Colors: 16.7M
- Trace Free Technology
- SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 6 Modes (sRGB Mode/Scenery Mode/Theater Mode/Standard Mode/Night View Mode/Game Mode)
- Skin-Tone Selection : 3 Modes
- Color Temperature Selection : 4 Modes
- HDCP support
- Stereo Speakers : 2W x 2 Stereo RMS
- Signal Input : HDMI , Dual-link DVI-D (support NVIDIA 3D Vision), DisplayPort
- PC Audio Input : 3.5mm Mini-Jack
- AV Audio Input : HDMI 1.4
- Audio Output : HDMI 1.4
- Earphone jack : 3.5mm Mini-Jack
- Power Consumption(Typical): <65W
- Power Saving Mode: <1W
- Power Off Mode: <1W
- Voltage: 100-240V, 50/60Hz
- Chassis Colors : Black
- Tilt : +15°~-5°
- Swivel : Yes
- Height Adjustment : Yes
- VESA Wall Mounting : 100x100mm
- Kensington lock
- Warranty: 3yr
Was [£269.99] Inc. VAT
Only £209.99 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 1200W Fully Modular "80 Plus Platinum" Power Supply - Black @ £149.99 inc VAT
Leadex Platinum series PSU are 80+ Platinum certified with 100% fully modular cable design, our R&D team's latest innovation, a brilliant idea to maximize PSU cables & connectors management to have the best cable routing solution, also increase case chassis air flow to have best cooling for your system.
Ledex series PSU provides high efficiency & stable power output and come with a 14cm two-way thermal control intelligent cooling fan to ensure your professional PC system will work under heavy load, also capable of powering your PC system equipped with NVIDIA® SLI™ or ATI CrossFireX™ setup.
Features:
- 100% Full Modular Cabling Design For Easy Cable Management<br />
- 80 PLUS ® Platinum Certified, 91.07% 92.44% 90.47% Efficiency At 20% 50% 100% Rated Load<br />
- Full Range Auto Voltage Detection Design 100V~240V (Active PFC)<br />
- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification<br />
- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation<br />
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection<br />
- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards<br />
- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card<br />
- Patented Easy To Use & Install Crystal Clear Cube Connectors with LED<br />
- More than 2,000 times On/Off test<br />
- Unleaded Green Materials with RoHS/WEEE Compliance<br />
- Perfect For Professional & High Performance Gaming System
</p>
<br /><br />
<p>
<h1>Specification:</h1>
- Type: ATX <br />
- Maximum Power: 1200W <br />
- Fans: 1 x 14cm <br />
- PFC: Active <br />
- +12V Rails: 1 <br />
- Modular Cable: Yes 100% modular cable design <br />
- Input Voltage Full Ranage - 100V~240V <br />
- Input Frequency Range 50 ± 3 Hz / 60 ± 3 Hz <br />
- Output +3.3V@20A ; [email protected] ; [email protected] ; [email protected] ; [email protected] <br />
- Protection OVP?OCP?OPP?SCP?UVP <br />
- Dimension 200mm(L) x 150mm(W) x 86mm(H) <br />
- 1x 20+4-Pin ATX12V/EPS12V<br />
- 1x 8-Pin EPS12V<br />
- 1x 4+4-Pin ATX12V/EPS12V<br />
- 8x 6+2-Pin-PCIe<br />
- 10x SATA<br />
- 5x 4-Pin-Molex<br />
- 1x Floppy<br />
- Warranty: 5yr
Was [£179.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
