Just about to go xfire 290's. Few questions.
1 Jun 2004
Will my old i5 2500k sandy at 4.5ghz bottleneck them? Tried my hardest to get it past 4.5 but i'm on air and it won't play ball.
I have a Seasonic M12II EVO 850W psu. Only using 2 hard drives, 3 case fans and no optical drive. Would this suffice?
What resolution and what games will you be playing?
I'm 1920x1080 currently but will be stepping up to 2k or 4k.
I play a bit of everything really but mainly Dayz (if it ever gets sorted) Arma 3 BP. Planetside 2, Dota 2. I always try something new when it comes out though.
Grand, well you'll be fine then. The higher the resolution you go, the less the cpu bottleneck will become. If you could eventually fit an i7 in there even better.
you need decide your screen before you pick your hardware these days
more than ever
id start there, find a screen you happy with :)
*waves matt*
more than ever
*waves matt*
I'll leave in the charming and capable hands of our resident Monitor expect, Mei. :D :cool: :p
*waves and runs*
Oh cool! Glad the bottleneck goes off cpu at higher res. I don't really intend on changing my motherboard soon so I was debating dropping in an i7 3770k but wasn't sure if i'd really see that much difference with my 2500k 4.5ghz?
Yep I'd definitely recommend doing that. Not only will you get a cpu with more threads which will perform better with two gpu's, it will also be a bit faster clock for clock and you will double your pci-e bandwidth which will be crucial at 4k. :)
Just wondering, why 24GB ram? 8>16>32
How did you get 24GB to work? Just wondering....:cool:
