** CORSAIR DDR4 NOW AVAILABLE: OcUK FIRST AGAIN!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OcUK does it again and has Corsair DDR4 now available for pre-order, check them out here:-
Corsair Dominator Platinum 16GB (4x4GB) DDR4 PC4-21300C15 2666MHz Quad Channel Kit (CMD16GX4M4A2666C15) @ £319.99 inc VAT
Dominator Platinum high-performance DDR4 memory is designed for world-class system builds. It's built with hand-screened ICs, undergoes rigorous performance testing, and incorporates patented DHX cooling for reliable performance in demanding environments.
The DDR4 form factor is optimized for the latest Intel X99 Series motherboards, and modules are compatibility-tested across multiple X99 Series motherboards for reliably fast performance. Extracting maximum performance is easy -- built-in XMP 2.0 support gives you trouble-free, automatic overclocking.
Dominator Platinum modules work with the Corsair Link system for temperature monitoring, and you can even enhance the subtle white LED lighting by adding a light bar kit (available separately) to match or contrast it with your system.
Specification:-
- 2666MHz (PC4-21300)
- CAS Timings: 15-17-17-35
- Voltage: 1.20v
Only £319.99 inc VAT.
ORDER NOW
Corsair Dominator Platinum 16GB (4x4GB) DDR4 PC4-23000C16 2800MHz Quad Channel Kit (CMD16GX4M4A2800C16) @ £399.95 inc VAT
Specification:-
- 2800MHz (PC4-23000)
- CAS Timings: 16-18-18-36
- Voltage: 1.20v
Only £399.95 inc VAT.
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-21300C15 2666MHz Quad Channel Kit - Black (CMK16GX4M4A2666C15) @ £239.99 inc VAT
Vengeance LPX memory is designed for high-performance overclocking. The heatspreader is made of pure aluminum for faster heat dissipation, and the eight-layer PCB helps manage heat and provides superior overclocking headroom. Each IC is individually screened for performance potential.
The DDR4 form factor is optimized for the latest Intel X99 Series motherboards and offers higher frequencies, greater bandwidth, and lower power consumption than DDR3 modules. Vengeance LPX DDR4 modules are compatibility-tested across X99 Series motherboards for reliably fast performance. There’s XMP 2.0 support for trouble-free automatic overclocking. And, they’re available in multiple colors to match your motherboard, your components, or just your style.
Specification:-
- Voltage: 1.20v
Only £239.99 inc VAT.
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-21300C15 2666MHz Quad Channel Kit - Red (CMK16GX4M4A2666C15R) @ £239.99 inc VAT
Specification:-
- Voltage: 1.20v
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-23000C16 2800MHz Quad Channel Kit - Black (CMK16GX4M4A2800C16) @ £299.99 inc VAT
Specification:-
- Voltage: 1.20v
Only £299.99 inc VAT.
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-23000C16 2800MHz Quad Channel Kit - Blue (CMK16GX4M4A2800C16B) @ £299.99 inc VAT
Specification:-
- Voltage: 1.20v
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-23000C16 2800MHz Quad Channel Kit - Red (CMK16GX4M4A2800C16R) @ £299.99 inc VAT
Specification:-
- Voltage: 1.20v
ORDER NOW
Some nice looking kits from Corsair and OcUK brings you them first!! :)
Who what where. What about the Crucial? :)
Where are the faster Corsair kits fella? I thought the Plats were going to launch with stuff that hits 4000mhz.
Crucial middle of September for their nice stuff!
Corsair maximum speed right now is 2800MHz.
G.Skill soon! :D
just ordered my corsair
now need my new intel chip, motherboard and NVidia gfx then im set for the rest of the year :p
I wonder what corsair hydro will work on this chipset.
