Watercooling checklist - Finally!!
27 Apr 2012
London
After more than 10 years thinking about getting into watercooling, finally it will happen.
Am I missing something?
This is what I already bought:
1x Phanteks Enthoo Primo
1x XSPC AX360 + 6x Corsair SP120 HP Push/Pull
1x XSPC AX360 + 3x Corsair SP120 HP
1x XSPC AX120 + 1x Corsair SP120 HP
1x XSPC EX240 + 2x Corsair SP120 HP
2x Koolance CTR-SPD1224M 12V or 24V Pump/Fan Controller
1x Laing DDC-1T Plus Pump (18W)
1x Laing DDC-1T Pump (10W)
1x XSPC Acrylic Top for Laing DDC
1x EK-DDC Heatsink Housing - Black
1x EK-DDC Heatsink Housing - Nickel
1x XSPC Raystorm CPU Block
3x EK GPU blocks
6x EK-PSC Revolvable angled adaptor 45° G1/4 Black
2x EK Revolvable angled adaptor 45° G1/4 Black Chrome
2x EK-PSC Revolvable angled adaptor 90° G1/4 Black
2x Alphacool angled adaptor double 45° revolvable G1/4
1x Phobya Balancer 150 black nickel Reservoir + extra 250 tube (GPUs)
1x XSPC Acrylic Dual 5.25” Reservoir for Two Laing DDC (CPU)
20x XSPC G1/4" to 7/16" ID, 5/8" OD Compression Fitting - Black Chrome
6x XSPC G1/4" to 7/16" ID, 5/8" OD Compression Fitting - Chrome
20x Phobya O-Ring 11,1 x 2mm - G1/4 – UV-reactive blue
3x Feser Pass Through Connector - Fill / Drain Port - G1/4
2x Feser Sli/Crossfire waterblock connector for 1/2/3 slots
7x Masterkleer tubing PVC 15,9/11,1mm (7/16ID) UV-active silver (7 Meters)
1x Mayhems XT-1 150ml Clear Coolant
20x DI water (20 Litres)
Change of plans, will go dual loop with the CPU using the Laing 10W and 1x360 rad.
Spare parts:
1x Hardware Labs Black Ice GT Stealth 120 + 1x Corsair SP120 HP
2x Aquacomputer DDC Top
Yeah, you're good to go with the obvious exception of no GPU's/Blocks :)
Not sure why you need the orings though, but it doesn't matter and I'm just being picky :D Why do they make them uv reactive when you can't even see them anyway?
Probably I will wait for the 880s to come out, hope it happens soon.
Actually I don't even need them, I just bought to keep as spare. (It was £2 for 20, so why not)
I really don't know why they made then uv reactive, but it was on sale, so it was cheaper than the black ones :)
^ as petey has said virtually all O ring fitting are designed to conceal the O ring :)
Yeah and they make it in so many colors, don't know why :)
