I have been converting a video files from X to Y in oder to compare the speeds of my PCs, and I was looking at the disdplayu on the keyboard, and it was only floating at 10 or 11%
So, this got me doing a bit of twiddling about and sure enough, a load of the cores are parked, so I unpark them all, get the PC running full-speed but it makes ZERO difference. Im still running at 10%
I look tat he task manager and I see it eating Core 3 @ a good 90% or more but the other cores are almost untouched.
I try forcing the software to both use up all the cores, and it does nothing.
I try out different software and that does not help either?
I then tried Folding at home and sure enough, that eats all my cores at the full 100% as its supposed to, so that must means that the CPU is ok, but why does it keep doing this then?
