** MONITOR CALIBRATOR NOW AVAILABLE FOR LG MONITORS!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
For those who wish to calibrate their monitor colours, we have the tool:-
LG Electronics LG COLOUR CALIBRATOR ACB8300 ML - ACB8300.AEU @ £29.99 inc VAT
The LG Colour Calibrator is a simple solution to ensure your monitor is always displaying the correct colours. The LG Colour Calibrator delivers quick and easy monitor calibration for your laptop or desktop monitor. LG Colour Calibrator includes a measurement device and simple to use software. It’s easy, simply plug the device into your USB port and follow the on-screen instructions.
*Should be noted that this will only work with LG monitors via the True Color Finder software."
Only £29.99 inc VAT.
ORDER NOW
What this ?
From the link it says " *Should be noted that this will only work with LG monitors via the True Color Finder software."
i'm not entirely convinced it would work with all LG monitors either. It works for hardware calibration on the LG 34UM95, but not sure whether or not it can be used for software profiling/calibration on any other monitors. Will try and check....
I sure I would not be alone in being very interested in the results of your testing on other monitors :)
just to confirm, i've checked and the device only works with compatible LG monitors. It also only works with the LG True Color software package.
