** HOT GTX 780 DEALS - LIMITED STOCKS! **
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
KFA2 GeForce GTX 780 3072MB PCI-Express Graphics Card - Retail (78XNH5DN9IST) @ £319.99 inc VAT
The next generation GeForce GTX 780 is a high-performance graphics card designed from the ground up to deliver super-fast, smooth and quiet gaming. It features the most advanced technology innovations, engineering and features to deliver spectacular performance in today's most demanding games.
Features:-
- Gigantic 3GB GDDR5 memory for the best gaming experience & the best resolution
- NVIDIA GPU Boost 2.0 Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers new levels of customization, including GPU temperature target, overclocking, and unlocked voltage
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- GPU: GeForce GTX 780
- Core Base Clock: 863 MHz
- Core Boost Clock: 900 MHz
- Memory Clock: 6008 MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
- Hexus Review: http://hexus.net/tech/reviews/graphics/55577-kfa2-geforce-gtx-780-sli/?page=12
Was [£323.99] Inc. VAT
Only £319.99 inc VAT.
ORDER NOW
MSI Geforce GTX 780 Gaming Edition OC 3072MB GDDR5 PCI-Express Graphics Card @ £329.99 inc VAT
The new GeForce GTX 780 is all about hyper-realistic gaming and next generation technology. The GeForce GTX 780 features the same record-breaking GK110 GPU used in GeForce GTX TITAN. The massively powerful NVIDIA Kepler ™ based GPU contains 50% more cores than its GTX 680 predecessor AND comes with 3GB of high-speed GDDR5 and NVIDIA GPU Boost 2.0 technology. GeForce GTX 780's 384-bit memory interface provides up to 288.4GB/sec of peak memory bandwidth to the GPU. All this combines to give you over a 40% gaming performance upgrade.
Features:-
Specification:-
- Core Base Clock: 954 MHz
- Core Boost Clock: 1006 MHz
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£359.99] Inc. VAT
Only £329.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 780 WindForce 3x OC Rev2.0 3072MB GDDR5 PCI-Express Graphics Card (GV-N780OC-3GD) @ £329.99 inc VAT
Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up MONITORING, GPU CLOCK, MEMORY CLOCK, FAN, GPU VOLTAGE, Memory VOLTAGE, OSD, ONLINE SUPPORT and update driver, BIOS directly.
Keeping the same 450W Cooling capacity using only 2 slots, the New WINDFORCE 3X 450W cooling system is equipped with two 8mm and four 6mm cooper heat-pipes , inclined fans, and GIGABYTE “Triangle Cool” technology. This not only provides an effective heat dissipation capacity but GPU Boost 2.0 technology also enables higher performance due to a lower temperature.
In the Kepler architecture, support up to four displays on a single card. Satisfy your mulit-screen steup, high definition and extreme gaming experience.
Features:-
Specification:-
- Rev2.00
- WINDFORCE 3X 450W Cooling system
- Black PCB
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power Connectors: 2x8-Pin
- Warranty: 3yr
ORDER NOW
Asus GeForce GTX 780 Direct CU II 3072MB GDDR5 PCI-Express Graphics Card @ £329.99 inc VAT
NVIDIA GeForce GTX 780 is now great value for money with technologies such as GeForce Experience, TXAA, 3D Vision 2.0 making the latest games such as Titanfall not only look out of this world but playable with silky smooth frame rates.
The newly arrived ASUS GTX780-DC2-3GD5 ships with 28nm GPU and 3GB GDDR5. To fully harness the power of new GPU technology, ASUS GTX780-DC2-3GD5 built with ASUS exclusive DirectCU II design featuring a 40% more efficient 10mm copper heat-pipe, 2.2X larger dissipation surface are and unique CoolTech fan that ensures 30% cooler and up to 3X quieter performance than reference. For enhanced overclocked headroom and gaming experience, ASUS redesign GTX780 with DIGI+ VRM offering precise digital delivery for better software overclocking stability. For enhanced overclocked headroom, ASUS GTX780-DC2-3GD5 uses 8+2 phase power design in Super Alloy Power technology, compared to 6+2 phase power design in reference card. In addition, GPU Tweak utility helps users modify and tune boost clock speed, power target, temperature target and fan performance via an intuitive interface. This card uses PCI Express 3.0 as the standard interface, doubling the data bandwidth of PCI Express 2.0. The power of ASUS GTX780-DC2-3GD5 also supports NVIDIA® Adaptive VSync technology and 3D Vision® surround™. ASUS GTX780-DC2-3GD5 provides fantastic gaming experience!
Features:-
- 30% cooler and 3X quieter performance with ASUS exclusive DirectCU II thermal solution
- ASUS uses 8+2 phase power design in DIGI+ VRM and Super Alloy Power technology for precise digital delivery and enhanced overclocked headroom.
- GPU Tweak utility allows you to tune graphics card performance and check card status via an intuitive interface
Specification:-
- Core Boost Clock: 902 MHz
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£379.99] Inc. VAT
ORDER NOW
The 780 won't be available for much longer so anyone wanting a great deal or is considering an SLI upgrade, then do not wait too long. :)
Ooooooooh, will there be special EOL sales like for the 6XX series? :D
This is it, 780 is in very short supply.
The special EOL sales were because many still had huge overstocks on 6xx series whereas 780's are now in short supply.
Would be epic to do a 780 at say £250 but NVIDIA lost huge money on 6xx deals, guess they learnt from that. ;)
Will there be any EOL NVIDIA sales for 700 series, or is the stock running low for most models, as opposed to just the 780's?
770 is current and also short but it's our best selling SKU as very popular in systems. 780 prices is dropped and 780Ti is stable.
Little over a year old and 780's already in this condition. Could be handy then if mine goes **** up with it's 5 year warranty. Last time I replaced a card on warranty I went from an 8800GTS to 9800+.
Some decent value there to be had for someone wanting a decent upgrade.
Happy with my set up for now, waiting on 9xx probably
