UK companies selling high end Xeon workstations?
5 Feb 2013
Hi all,
I am interested in investing in a dual E5-2697 V2 ( or maybe E5-2695 V2) workstation. The sole purpose for the workstation will be 3D rendering, nothing else.
I am not interested in purchasing several cheaper nodes, just the aforementioned dual E5-2697 V2 workstation.
I can't seem to find any companies selling already built workstations with that specific CPU though. Just a company called Cutesi and their price was quite good actually- 3,901.99 GBP.
I don't want to build it myself since I have little experience with such high end hardware, besides buying the assembled workstation sometimes proves to be cheaper than putting it together by yourself.
So, anyone knows UK based companies selling such workstations?
Thanks.
For the rendering part it's all about the CPU cores (my renderer is CPU based).
For the modelling and view-port navigation before that- the GPU does make a difference but not that much any more (unless you are using a very low end GPU).
Cheers.
Cheers.
Pro GPUs are a con really now. I reckon that's why nVidia nerfed the DP64 performance on their cards, to give pros actual reasons to buy their pro cards.
This has been going on forever, from both teams
Sure, AMD's pro cards are also a con as well, I wouldn't dispute that, however it's only nVidia that has killed the DP64 performance in this sort of way which had a carry over to some DX11 features performance. Though that isn't really a subject for this thread, I was just pointing out the pro cards being a con.
Hi there branskyj,
We can do this for you not a problem at all.
If you need anything feel free to give us a shout.
Call us on 01782 44 44 55 or drop an email in and we can spec you a full workstation
Regards
Bailey
Well feel free to give me a shout if you need anything.
I can get you sorted to a customised workstation to suit your needs.
Regards
Bailey
