3770K Delid
29 May 2012
Dorset
Going to hit my cpu with a hammer soon, Dont have massive issues with performance but my temps could be a lot better and i feel that im not getting the best out of my loop.
One quick question though Coollab paste LP vs LU which is best for die to ihs?
I used Ultra.
Don't hammer it, use a razor like a pro. I did a guide can find you a link if you'd like, it's on another forum though....
Don't use a knife, I did my 3770k around 2 months ago in a vice with a hammer.
Was my first time de-lidding anything and went smooth as silk.
Too much risk when using a knife.
Thinking of hitting mine with a hammer, be cheaper than going to X99 if it works ok. Shame though when you have to resort to this on a k chip sold for it's oc potential.
Except if you know what you are doing or aren't a complete yob.
Except its a long drawn out process you do blind, you cannot see whats underneath or how near stuff you are, doing it for the 1st time is RISKY, hammer method is safer, you don't do anything 'blind'...........the only thing I suggest is google a pic of the die under neath the IHS and make sure the long edge is the same direction to which you hit the hammer.......this gives more clearence for the IHS to move and pop up before even contacting the CPU die.
I did mine really easy and now get 30c/67c temps idle load.
I spent about an hour hitting my 3770k from various angles with a hammer (also tried the method with using the vice to "push" the IHS off) and got nowhere.
It took about five minutes with a razor.
