** CORSAIR DOMINATOR DDR4 3200MHz!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Corsair are winning the speed race with DDR4:-
Corsair Dominator Platinum 16GB (4x4GB) DDR4 PC4-25600C16 3200MHz Quad Channel Kit (CMD16GX4M4A2800C16) @ £499.99 inc VAT
Dominator Platinum high-performance DDR4 memory is designed for world-class system builds. It's built with hand-screened ICs, undergoes rigorous performance testing, and incorporates patented DHX cooling for reliable performance in demanding environments.
The DDR4 form factor is optimized for the latest Intel X99 Series motherboards, and modules are compatibility-tested across multiple X99 Series motherboards for reliably fast performance. Extracting maximum performance is easy -- built-in XMP 2.0 support gives you trouble-free, automatic overclocking.
Dominator Platinum modules work with the Corsair Link system for temperature monitoring, and you can even enhance the subtle white LED lighting by adding a light bar kit (available separately) to match or contrast it with your system.
Specification:-
- 3200MHz (PC4-25600)
- CAS Timings: 16-18-18-36
- Voltage: 1.35v
Only £499.99 inc VAT.
ORDER NOW
Were also expecting a 3300MHz soon as well from Corsair!! :eek:
true, true.....
I am gagging to upgrade to X99 but the RAM upgrade has killed it for me for now. we all know that in a few months all this stuff will be a fraction of the price it is now so for once I am going to hold fire. (it hurts though)
Dom plats are always dear but they do offer some great off the shelf performance. You pay for the binning. Only problem with DDR4 is it's still difficult to gauge just how tight they'll go so whether they're really worth anywhere near that much is questionable lol
this is another reason that i am gonna wait a bit. I was thinking about the next CPU's as well but the leaked roadmaps don't show anything until Skylake and the money would have burnt through my pocket well before thats released.
crazy price i will wait til 4600 kits and when they be lower then 100 £ , same as i did with these dominators gt's
edit: less then 100£ for 8 gig so less then 200 £ for 16 gig
