Is the Intel 5960X a native 8 core?
I remember the first Intel dual core being mocked for being "two chips glued together"... that was always the way when they were figuring out all this multi-core stuff. The 9800GX2 sandwich board for example. :D
Final production 5960 will likely be 8 core, constructed as such.
Wafers cost money, wasting wafers by making 12 cores then disabling cores could work out pretty expensive for Intel.
Unless of course they are making 8 core CPUs from failed 12 cores... AMD do a lot of this. Basically knock out 8 core CPUs then disable or cut out cores that don't work to prop up their lower end models.
I doubt it though, because as I said, wafers cost money.
