HTPC Upgrade -Need advice.
18 Oct 2007
Looking to upgrade my HTPC as I can't really play many games any more and I think it's mostly down to the CPU.
HTPC atm
[email protected]
4GB Memory DDR2
P5Q-E
HD7850
Considering..
Intel Pentium K Anniversary G3258 £49.99
Asrock H97 Pro4 Intel H97 - £64.99
Corsair XMS3 8GB - £67.99
HD7850 - No change as I think it's probably enough.
So is this worth it? thoughts? Not sure about the G3258 but it does seem very well priced.
Reviews have been very good considering it dual core, In some instances it does drop behind the quad-core options a lot but compared to me Q9550 it should still be an improvement, and yes I will be overclocking.
If you plan on overclocking, wouldn't you need a Z97 board!
