Thanks for this 8pack. I always prefer real world results rather than ones pulled from an air conditioned room with golden CPUs.
Silicon Lottery!!
I think average will be 4.3-4.4. Good is 4.6 and amazing is 4.8-4.9. Most I tested on dual where 4.3-4.4.
With these chips Uncore makes a big difference!!! So its important also. You get 4g Uncore and 4.4 this is like 4.6+ chip with 3.3 uncore.
Then memory is also important 2666 C10 and above your set.
Damn
/packs golden cpu's and air-con unit away
Dude you'd be amazed how many times I've bought a group winning cooler based on a review only to find I'm running 10c hotter than their results.
Bit-tech are famed for it. Their offices are all air con.
No memory OC needed.
Not tried!!! Gibbo wont let me as he wants em to remain in stock!! I know very ragtag!!! I told him so!!
No I dont think you will get 4.5 easy at all.
Higher like, a lot higher or 100-200MHz?
Do you think I'll manage 4.5GHz easily on a 5820k with good cooling?
Thanks for your thoughts!
